| Windows 7: Help! Problem with system restore and SMART Hard Drive detection |
12 Sep 2012
#1 | | |
Help! Problem with system restore and SMART Hard Drive detection Hi,
I have a Dell XPS laptop which for whatever reason decided one day not to boot. I took the opportunity to do a backup and full restore using Dell DataSafe (?) which crashed and got stuck at 29%. On attempting to restart my computer I receive an error message from SMART that my hard drive is about to fail, and despite me furiously tapping f8 to enter safe mode the error screen always overrides the safe boot menu (which I sometimes see for half a second but never long enough to do anything about it).
The backup I did using DataSafe prior to my first system restore is on a partition went to a partition on my C:\ drive so I'm loathed to switch out the HDD completely at this point.
I just want to boot in safe mode so that I can move my backup to my external HDD but I can see absolutely no way to do so. I have tried using bcdedit in the command prompt but I get the exact same thing when restarting the computer, just this time in safe mode - still no option to attempt to boot. I have no SMART options in BIOS so apparently I'm stuck with the error message!
I'm sure there are plenty of specifics I've missed out that I can provide if anybody has any ideas, just a case of jogging my memory! I've spent all day trying to work this out and it is beginning to drive me insane.
Thanks for your time (and hopefully help).
Will | My System Specs |
| OS Windows 7 Ultimate x64 |
12 Sep 2012
#2 | | Windows 7 Home Premium 32bit |
SMART HDD is a virus It is a fake virus and I have it too! Fortunately I have my trusty iPad!
Anyway, do a google search on SMART HDD and you will see what I am talking about.
I ended up having to buy PC Tools ($40 Australian) to get rid of the virus though I am not 100% sure if it is completely gone. http://http://www.pctools.com/forum/...DD-Smart-Check
I have hopefully pasted in the link I am referring to.
For my particular issue I think I am going to have to reload the OS. At present I am backing up to DVDs because any USBs or external HDD is not recognised.
The good news is that once you follow the instructions and unhide your data should still be there. Good luck. | My System Specs | | OS Windows 7 Home Premium 32bit |
13 Sep 2012
#3 | | |
Thanks for the help - I'll give it a go. Just seems odd that I only receive now after a failed restore.
The problem is is that I can't boot so can't download anything. All I have is BIOS and cmd.exe. | My System Specs | | OS Windows 7 Ultimate x64 |
13 Sep 2012
#4 | | Windows 7 Ultimate X64 SP1 Mt. Crumpit/Whoville |
S.M.A.R.T. is most definitely not a virus. Self-Monitoring, Analysis and Reporting Technology
Can you boot to Windows 7 at all, any kind of way?
In cmd prompt type And let it run. | My System Specs | | Computer type PC/Desktop System Manufacturer/Model Number Home Built Desktop By DataTech OS Windows 7 Ultimate X64 SP1 CPU Intel i5-2550K, Differing ~4.4-4.8GHz No built in GPU Motherboard ASUS P8Z68-V PRO/GEN3 Memory 16GB G.Skill Sniper 2133MHz 4x4GB Graphics Card ASUS ENGTX460 DirectCU/2DI/1GD5 GeForce GTX 460 Sound Card Onboard Realtek 5-1 Monitor(s) Displays Samsung P2570HD Screen Resolution 1920x1080 Keyboard Old, beat-up Dell USB From 10 yrs Ago Mouse Gigabyte m6900 wired PSU Corsair HX650W Case Inwin Dragon Rider Cooling Hyper 212 EVO w/two Noctua fans, push-pull, @1300 RPM Hard Drives Crucial M4 128GB for OS, 750GB Seagate MomentusXT for data, 500GB Seagate Constellation for storage Internet Speed 8-19 Mbs down, 3-4 Mbs up Comcast Cable Antivirus Norton Internet Security Browser IE 9, Opera when needed Other Info 4 case fans, LG BluRay-RE, ASUS DVD-RW, Mr. Fusion power generator with flux capacitor, 1.21 gigawatts. |
13 Sep 2012
#5 | | Windows 7 Enterprise x64 Austin |
Hi, I would recommend running Dell Diagnostics. In order to run Dell Diagnostics from Hard Drive, follow the mentioned steps: Restart your computer. When the DELL™ logo appears, tap <F12> immediately. In the boot device list, highlight Boot to Utility Partition and press <Enter>. Under Dell Diagnostics Main Menu (see Dell Diagnostics Main Menu), select the extended test. If you get any error code, make a note of the error code. Kindly revert and let us know the status. | My System Specs | | OS Windows 7 Enterprise x64 |
13 Sep 2012
#6 | | |
Debbie B, I did as you said and received error no. 0142, and there was another code which was 2000 0142.
I will try your suggestion when I am home Britton, thanks. | My System Specs | | OS Windows 7 Ultimate x64 |
14 Sep 2012
#7 | | |
Quote: Originally Posted by Britton30 S.M.A.R.T. is most definitely not a virus. Self-Monitoring, Analysis and Reporting Technology
In cmd prompt type And let it run. I get the following: Chkdsk cannot run because the volume is in use by another process. Chkdsk may run if this volume is dismounted first. ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID. Would you like to force a dismount on this volume?
Do I!? | My System Specs | | OS Windows 7 Ultimate x64 |
14 Sep 2012
#8 | | Windows 7 SP1, Home Premium, 64-bit |
Yes, if you want to run Chkdsk. All that means is that the drive in question is being used at the moment.
If you force the dismount, the PC should reboot and run chkdisk before Windows is loaded. | My System Specs | | System Manufacturer/Model Number Ignatz Special; 4 speed manual gearbox; factory air conditioning; one of one OS Windows 7 SP1, Home Premium, 64-bit CPU Intel Sandy Bridge i5-2500, not overclocked Motherboard Gigabyte H67A-UD3H-B3, full ATX Memory 4 GB Crucial DDR3-1333 Graphics Card none; graphics are integrated on CPU Sound Card onboard: Realtek ALC892; external: USB Behringer UF0-202 Monitor(s) Displays NEC 90GX2-BK 19" LCD Screen Resolution 800 x 640 Keyboard Leopold Tenkeyless with Cherry Blue switches, USB Mouse Logitech or Microsoft optical wired; either USB or PS 2 PSU Seasonic SS-560KM, modular Case Antec Solo II Cooling CPU: Scythe Big Shuriken; Case: Scythe Slipstream 800 & 500 Hard Drives System: Intel 320 Series SSD, 80 GB;
Backup: WD Caviar Green WD15EADS-00P8B0, 1.5TB Other Info Power consumption of this system, including monitor: 68 watts at idle; 144 watts at full load |
14 Sep 2012
#9 | | Windows 7 Enterprise x64 Austin |
Hi, According to support website”2000-0142” relates to hard drive issue. You can even try Removing and reinstalling the Hard Drive for this error codes. Ensure to disconnect the power source from the computer while reseating Hard Drive. After reinstalling the hard drive re-run the Diagnostics. Also, would suggest you to check the hard drive status in system BIOS. If the status is unknown, then I would recommend resetting the BIOS to default. If you still get the status “unknown” in BIOS and if you still get the same error code, then your computer hard drive might be bad and needs to be replaced. Hope this helps. | My System Specs | | OS Windows 7 Enterprise x64 Help! Problem with system restore and SMART Hard Drive detection problems? All times are GMT -5. The time now is 05:03 PM. | |
