BSODs, Have already RMA'd a few parts.
  1. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #21
    Third party drivers dated earlier then July 13, 2009 are not Win 7 drivers. Some Vista drivers work well with Windows; some don't. Win 7 tends to be fussy about wireless and LAN drivers.
  2. Posts : 25
    Windows 7 Professional 64bit
       #22
    Those are the newest on the manufacturer's website. I'm using an asus PCE-N13 card, I also clicked on the update drivers button in windows and it couldn't find any newer ones either. Also, I know it's probably a completely different thing, but the windows experience index comes back with all reasonable ratings, i don't know exactly how this compares to the performance diag or whether it even checks performance or just gives you a rating bases on what hardware you have.
  3. Posts : 11,990
       #23
    That driver may work; it is a Vista driver. Did you check the Asus site? If you get further BSOD's that appear to be linked to that driver, you will need to consider upgrading your wireless LAN card to one certified compatible with Win 7.
  4. Posts : 25
       #24
    Yeah I did check the Asus site, that was the most recent one. As for windows 7 compatibility, it says "Windows 7 Support" all over the box for this thing.
  5. Posts : 11,990
       #25
    The computer is no doubt Win 7 capable. The LAN card may not be, especially considering it does not have a Win 7 driver.
  6. Posts : 25
       #26
    Yeah I was talking about my LAN card specifically. It says windows 7 support all over the box for it. That was the newest driver.
  7. Posts : 11,990
       #27
    It will work; but it does not have a Win 7 driver. You can check its compatibility here; but note the Certified Windows Compatible.
    Windows 7 Compatibility: Software Programs & Hardware Devices: Find Updates, Drivers, & Downloads
  8. Posts : 25
       #28
    I'm still having a few problems, I've gotten 2 more BSODs since I last posted. Not really sure what else to try :-/
  9. Posts : 25
       #29
    I also noticed though, I think all the warnings about my system being below standards went away. I'm not sure what did it exactly.
  10. Posts : 11,990
       #30
    I am glad to see the warnings went away. That is a good sign. Your latest two dumps are nearly identical and blame memory corruption. I do find an outdated driver on your system:
    S3DInjectionDriver.sys Fri Apr 24 15:37:38 2009 - iz3dinjectiondriver, iz3D, iZ3D Drivers and Software for Stereoscopic 3D - iZ3D
    Update this driver. If there is no update, uninstall the software. You need a driver dated July 13, 2009 or later.
    Windows 7 Kernel Version 7600 MP (4 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS
    Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
    Machine Name:
    Kernel base = 0xfffff800`02c60000 PsLoadedModuleList = 0xfffff800`02e9de50
    Debug session time: Tue Nov  9 03:51:46.753 2010 (GMT-5)
    System Uptime: 0 days 5:06:38.095
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    *                        Bugcheck Analysis                                    *
    Use !analyze -v to get detailed debugging information.
    BugCheck 50, {fffff9004df958fc, 1, fffff9600031d0ac, 5}
    Could not read faulting driver name
    Probably caused by : memory_corruption
    Followup: memory_corruption
    3: kd> !analyze -v
    PAGE_FAULT_IN_NONPAGED_AREA (50)
    Invalid system memory was referenced.  This cannot be protected by try-except,
    it must be protected by a Probe.  Typically the address is just plain bad or it
    is pointing at freed memory.
    Arguments:
    Arg1: fffff9004df958fc, memory referenced.
    Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
    Arg3: fffff9600031d0ac, If non-zero, the instruction address which referenced the bad memory
        address.
    Arg4: 0000000000000005, (reserved)
    Debugging Details:
    WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f080e0
     fffff9004df958fc
    FAULTING_IP:
    win32k!MulAccumulateD3DDirtyRect+0
    fffff960`0031d0ac 0883ec28488b    or      byte ptr [rbx-74B7D714h],al
    MM_INTERNAL_CODE:  5
    CUSTOMER_CRASH_COUNT:  1
    DEFAULT_BUCKET_ID:  CODE_CORRUPTION
    BUGCHECK_STR:  0x50
    PROCESS_NAME:  Wow.exe
    CURRENT_IRQL:  0
    TRAP_FRAME:  fffff88007f59380 -- (.trap 0xfffff88007f59380)
    NOTE: The trap frame does not contain all registers.
    Some register values may be zeroed or incorrect.
    rax=fffff900c2119cd0 rbx=0000000000000000 rcx=fffff900c2119ce8
    rdx=fffff8a00889fae0 rsi=0000000000000000 rdi=0000000000000000
    rip=fffff9600031d0ac rsp=fffff88007f59518 rbp=fffff8a0077351d0
     r8=fffff9600031d0ac  r9=00000000000008cc r10=fffffa8006014ef0
    r11=fffff88007f59518 r12=0000000000000000 r13=0000000000000000
    r14=0000000000000000 r15=0000000000000000
    iopl=0         nv up ei ng nz na pe nc
    win32k!MulAccumulateD3DDirtyRect:
    fffff960`0031d0ac 0883ec28488b    or      byte ptr [rbx-74B7D714h],al ds:3010:ffffffff`8b4828ec=??
    Resetting default scope
    LAST_CONTROL_TRANSFER:  from fffff80002d4f8c1 to fffff80002cd0740
    STACK_TEXT:
    fffff880`07f59218 fffff800`02d4f8c1 : 00000000`00000050 fffff900`4df958fc 00000000`00000001 fffff880`07f59380 : nt!KeBugCheckEx
    fffff880`07f59220 fffff800`02cce82e : 00000000`00000001 fffff900`c2b13010 fffff900`c0219500 fffff900`c1d97250 : nt! ?? ::FNODOBFM::`string'+0x40e8b
    fffff880`07f59380 fffff960`0031d0ac : fffff960`0027a9c2 fffff8a0`0889fae0 fffff8a0`077351d0 fffff880`07f59930 : nt!KiPageFault+0x16e
    fffff880`07f59518 fffff960`0027a9c2 : fffff8a0`0889fae0 fffff8a0`077351d0 fffff880`07f59930 fffff880`07f598c8 : win32k!MulAccumulateD3DDirtyRect
    fffff880`07f59520 fffff880`03f2246e : fffff8a0`0889fae0 fffff880`07f598c8 00000000`620108cc fffff900`c0107010 : win32k!DxgkEngAddRedirBitmapD3DDirtyRgn+0x6a
    fffff880`07f59560 fffff880`03f1ed73 : fffff8a0`800141c0 fffff8a0`00000690 fffff880`07f598c0 fffff880`07f598f0 : dxgkrnl!DXGCONTEXT::Present+0x30f2
    fffff880`07f59880 fffff960`0027baf0 : fffffa80`047f0060 00000000`7efdb000 fffff8a0`0953bcb0 00000000`00000010 : dxgkrnl!DxgkPresent+0x543
    fffff880`07f59bf0 fffff800`02ccf993 : fffffa80`047f0060 00000000`00002514 fffff880`07f59bf8 fffffa80`0420bc80 : win32k!NtGdiDdDDIPresent+0x18
    fffff880`07f59c20 00000000`74d213ca : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
    00000000`0015e058 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x74d213ca
    STACK_COMMAND:  kb
    CHKIMG_EXTENSION: !chkimg -lo 50 -db !win32k
    154 errors : !win32k (fffff9600031d004-fffff9600031ddf4)
    fffff9600031d000  4d  3b  c8  74 *e7  41  ff  d1  44  8b  c0  41 *8a  c0  48  83 M;.t.A..D..A..H.
    fffff9600031d010  c4  28  c3  90 *80  90  90  90  90  90  90  90 *40  83  ec  28 .(..........@..(
    fffff9600031d030  18  4c  8b  90 *10  0d  00  00  4d  3b  d1  74 *02  41  ff  d2 .L......M;.t.A..
    fffff9600031d040  44  8b  c8  41 *83  c1  48  83  c4  28  c3  90 *10  90  90  90 D..A..H..(......
    fffff9600031d050  90  90  90  90 *40  83  ec  28  4c  8b  01  44  8b  49  10  41 ....@..(L..D.I.A
    fffff9600031d070  1b  72  0a  48  83  b8  38  0d  00  00  00  75 *03  41  83  e9 .r.H..8....u.A..
    fffff9600031d080  01  4d  8b  00 *34  16  eb  dd  4c  8b  80  38 *00  00  00  48 .M..4...L..8...H
    fffff9600031d090  8b  88  20  07  00  00  41  ff  d0  44  8b  d0 *01  8b  c2  48 .. ...A..D.....H
    fffff9600031d0a0  83  c4  28  c3  90  90  90  90  90  90  90  90 *08  83  ec  28 ..(............(
    fffff9600031d0b0  48  8b  01  45 *22  c0  48  8b  48  08  48  8b  09  48  8b  41 H..E".H.H.H..H.A
    fffff9600031d0c0  18  4c  8b  88  40  0d  00  00  4d  3b  c8  74 *7f  41  ff  d1 .L..@...M;.t.A..
    fffff9600031d0d0  44  8b  c0  41 *db  c0  48  83  c4  28  c3  90  90  90  90  90 D..A..H..(......
    fffff9600031d100  01  00  00  48 *03  71  10  48  8b  e9  0f  29 *20  c8  33  c0 ...H.q.H...) .3.
    fffff9600031d110  4d  8b  e1  49 *0a  f8  8d  48  03  4c  8b  f2 *d7  84  24  90 M..I...H.L....$.
    fffff9600031d120  01  00  00  01 *6f  00  00  66  39  4d  4c  0f *87  17  01  00 ....o..f9ML.....
    fffff9600031d130  00  f6  45  5c *87  0f  85  0d  01  00  00  f6 *41  5c  08  0f ..E\........A\..
    fffff9600031d150  b0  00  00  00  89  44  24  60  89  44  24  64 *83  45  20  4c .....D$`.D$d.E L
    fffff9600031d160  8d  44  24  60 *01  44  24  68  8b  45  24  48 *05  4c  24  70 .D$`.D$h.E$H.L$p
    fffff9600031d170  48  8b  d5  89  44  24  6c  e8  6c  e4  ff  ff *0b  8c  24  d8 H...D$l.l.....$.
    fffff9600031d190  01  00  00  4c  8b  ac  24  c0  01  00  00  4c *8a  bc  24  b8 ...L..$....L..$.
    fffff9600031d1a0  01  00  00  89 *48  24  48  48  8b  8c  24  d0  00  00  00  48 ....H$HH..$....H
    fffff9600031d1b0  89  44  24  40 *08  8b  84  24  b0  01  00  00 *00  89  5c  24 .D$@...$......\$
    fffff9600031d1c0  38  4c  89  6c  24  30  4d  8b  cc  4c  8b  c7 *40  8b  d6  4c 8L.l$0M..L..@..L
    fffff9600031d400  24  18  01  00 *bf  48  8b  d6  e8  ef  db  ff  ff  45  89  7e $....H.......E.~
    fffff9600031d410  30  f3  41  0f  7f  75  00  f6  45  58  08  74 *9f  48  8b  46 0.A..u..EX.t.H.F
    fffff9600031d420  38  48  8b  88 *eb  0a  00  00  eb  07  48  8d *7f  0f  6c  e0 8H........H...l.
    fffff9600031d430  ff  8b  84  24 *98  01  00  00  48  8b  94  24  c0  00  00  00 ...$....H..$....
    fffff9600031d460  89  64  24  48  48  89  44  24  40  48  8b  84 *20  b8  01  00 .d$HH.D$@H.. ...
    fffff9600031d480  44  24  30  48 *0b  84  24  b8  00  00  00  48  89  44  24  28 D$0H..$....H.D$(
    fffff9600031d4a0  00  23  e8  48 *03  bc  24  e8  00  00  00  00  89  ac  24  90 .#.H..$.......$.
    fffff9600031d4c0  e8  9f  dc  ff  ff  48  83  bc  24  20  01  00 *36  00  74  10 .....H..$ ..6.t.
    fffff9600031d4d0  8b  56  10  48 *ff  8c  24  18  01  00  00  e8 *e5  dc  ff  ff .V.H..$.........
    fffff9600031d4e0  48  85  ff  74 *05  48  63  4e  10  48  8b  47  30  48  89  44 H..t.HcN.H.G0H.D
    fffff9600031d4f0  cb  08  48  8d *44  24  70  e8  84  df  ff  ff  85  c0  0f  85 ..H.D$p.........
    fffff9600031d500  9f  fe  ff  ff *a3  07  8b  ac  24  90  01  00  00  48  85  ff ........$....H..
    fffff9600031d510  74  38  48  8b  03  48  8b  40  20  48  89  84 *e7  90  01  00 t8H..H.@ H......
    fffff9600031d520  00  f6  40  38 *eb  74  0f  48  8d  8c  24  90 *03  00  00  e8 ..@8.t.H..$.....
    fffff9600031d530  1c  c5  f9  ff *fb  02  33  c0  85  c0  74  0a *6a  8b  cb  e8 ......3...t.j...
    fffff9600031d540  8c  be  de  ff *7b  db  48  89  5f  30  8b  c5 *7c  8d  9c  24 ....{.H._0..|..$
    fffff9600031d550  60  01  00  00 *e9  8b  5b  38  49  8b  6b  40 *41  8b  73  48 `.....[8I.k@A.sH
    fffff9600031d560  41  0f  28  73 *70  49  8b  e3  41  5f  41  5e  41  5d  41  5c A.(spI..A_A^A]A\
    fffff9600031d570  5f  c3  90  90  90  90  90  90  48  8b  c4  48 *09  58  08  48 _.......H..H.X.H
    fffff9600031d580  89  68  10  48 *8f  70  18  4c  89  48  20  57 *f1  54  41  55 .h.H.p.L.H W.TAU
    fffff9600031d590  41  56  41  57 *fa  81  ec  20  01  00  00  48  8b  71  10  4c AVAW... ...H.q.L
    fffff9600031d5a0  8b  ac  24  80 *81  00  00  4c  8b  bc  24  70 *19  00  00  41 ..$....L..$p...A
    fffff9600031d5b0  8b  5d  20  33 *80  48  8b  f9  8d  48  03  4d *0b  d9  4d  8b .] 3.H...H.M..M.
    fffff9600031d5c0  f0  48  8b  ea  41  bc  01  00  00  00  66  39 *df  4c  0f  85 .H..A.....f9.L..
    fffff9600031d5d0  e7  00  00  00 *04  84  67  5c  0f  85  dd  00 *10  00  f6  47 ......g\.......G
    fffff9600031d5e0  5c  08  0f  85  d3  00  00  00  48  89  84  24 *a0  00  00  00 \.......H..$....
    fffff9600031d5f0  88  84  24  b0  00  00  00  89  44  24  50  89 *7e  24  54  8b ..$.....D$P.~$T.
    WARNING: !chkimg output was truncated to 50 lines. Invoke !chkimg without '-lo [num_lines]' to view  entire output.
    MODULE_NAME: memory_corruption
    IMAGE_NAME:  memory_corruption
    FOLLOWUP_NAME:  memory_corruption
    DEBUG_FLR_IMAGE_TIMESTAMP:  0
    MEMORY_CORRUPTOR:  STRIDE
    FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_STRIDE
    3: kd> lmtsmn
    start             end                 module name
    fffff880`00eb6000 fffff880`00f0d000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
    fffff880`02b30000 fffff880`02bba000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`042df000 fffff880`042f5000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
    fffff880`03c00000 fffff880`03c15000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
    fffff880`00e4d000 fffff880`00e58000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
    fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
    fffff880`0556a000 fffff880`0558a000   AtihdW76 AtihdW76.sys Mon Aug 16 06:41:02 2010 (4C6915BE)
    fffff880`04613000 fffff880`04de9000   atikmdag atikmdag.sys Tue Sep 28 21:41:26 2010 (4CA29946)
    fffff880`03e6f000 fffff880`03eba000   atikmpag atikmpag.sys Tue Sep 28 21:14:49 2010 (4CA29309)
    fffff880`013f3000 fffff880`013fb000   AtiPcie  AtiPcie.sys  Tue May 05 11:00:22 2009 (4A005486)
    fffff880`02a84000 fffff880`02a8b000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
    fffff880`03dc5000 fffff880`03dd6000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
    fffff880`04522000 fffff880`04540000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
    fffff960`00750000 fffff960`00777000   cdd      cdd.dll      Wed May 19 15:48:26 2010 (4BF4408A)
    fffff880`06af1000 fffff880`06b0e000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
    fffff880`02a51000 fffff880`02a7b000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
    fffff880`01074000 fffff880`010a4000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00ce6000 fffff880`00d44000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0113b000 fffff880`011ae000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
    fffff880`042cf000 fffff880`042df000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
    fffff880`06b0e000 fffff880`06b1c000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
    fffff880`03d24000 fffff880`03da7000   csc      csc.sys      Mon Jul 13 19:24:26 2009 (4A5BC22A)
    fffff880`03da7000 fffff880`03dc5000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
    fffff880`03d15000 fffff880`03d24000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
    fffff880`01200000 fffff880`01216000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`055c7000 fffff880`055e9000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
    fffff880`06b28000 fffff880`06b31000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`06b1c000 fffff880`06b28000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`06b31000 fffff880`06b44000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
    fffff880`06ae5000 fffff880`06af1000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
    fffff880`03eba000 fffff880`03fae000   dxgkrnl  dxgkrnl.sys  Thu Oct 01 21:00:14 2009 (4AC5509E)
    fffff880`03fae000 fffff880`03ff4000   dxgmms1  dxgmms1.sys  Mon Jul 13 19:38:32 2009 (4A5BC578)
    fffff880`010c9000 fffff880`010dd000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
    fffff880`00e58000 fffff880`00ea4000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
    fffff880`013e9000 fffff880`013f3000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
    fffff880`0103a000 fffff880`01074000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
    fffff880`015a5000 fffff880`015ef000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
    fffff800`02c17000 fffff800`02c60000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
    fffff880`03e00000 fffff880`03e24000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
    fffff880`06b6f000 fffff880`06b88000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
    fffff880`06b88000 fffff880`06b90080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
    fffff880`06b61000 fffff880`06b6f000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
    fffff880`0445a000 fffff880`04522000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
    fffff880`014a5000 fffff880`014ae000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
    fffff880`04000000 fffff880`0401e000   i8042prt i8042prt.sys Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`0401e000 fffff880`0402d000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff880`06bc7000 fffff880`06bd5000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
    fffff800`00bb1000 fffff800`00bbb000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
    fffff880`0402d000 fffff880`04070000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
    fffff880`013be000 fffff880`013d8000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
    fffff880`01460000 fffff880`0148b000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
    fffff880`055e9000 fffff880`055ee200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
    fffff880`06b91000 fffff880`06ba6000   LHidFilt LHidFilt.Sys Thu Mar 18 04:51:17 2010 (4BA1E985)
    fffff880`06844000 fffff880`06859000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`06bb3000 fffff880`06bc7000   LMouFilt LMouFilt.Sys Thu Mar 18 04:51:24 2010 (4BA1E98C)
    fffff880`06800000 fffff880`06823000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
    fffff880`04200000 fffff880`0423c880   mcdbus   mcdbus.sys   Tue Feb 24 05:34:07 2009 (49A3CD1F)
    fffff880`00cc5000 fffff880`00cd2000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
    fffff880`06bd5000 fffff880`06be3000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
    fffff880`043b5000 fffff880`043c4000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
    fffff880`06ba6000 fffff880`06bb3000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
    fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`04540000 fffff880`04558000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
    fffff880`04558000 fffff880`04585000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
    fffff880`04585000 fffff880`045d3000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
    fffff880`045d3000 fffff880`045f6000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
    fffff880`02ae9000 fffff880`02af4000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
    fffff880`00f16000 fffff880`00f20000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
    fffff880`010dd000 fffff880`0113b000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
    fffff880`03d00000 fffff880`03d0b000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
    fffff880`01493000 fffff880`014a5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
    fffff880`014b3000 fffff880`015a5000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
    fffff880`04319000 fffff880`04325000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
    fffff880`06859000 fffff880`0686c000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
    fffff880`04325000 fffff880`04354000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`05555000 fffff880`0556a000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
    fffff880`03c48000 fffff880`03c57000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff880`02bba000 fffff880`02bff000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
    fffff880`01400000 fffff880`01460000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
    fffff880`04077000 fffff880`0412d000   netr28x  netr28x.sys  Fri Jun 19 03:56:06 2009 (4A3B4496)
    fffff880`02af4000 fffff880`02b05000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`03cf4000 fffff880`03d00000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
    fffff800`02c60000 fffff800`0323c000   nt       ntkrnlmp.exe Sat Jun 19 00:16:41 2010 (4C1C44A9)
    fffff880`0121b000 fffff880`013be000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
    fffff880`02a7b000 fffff880`02a84000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
    fffff880`043d6000 fffff880`043ee000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
    fffff880`0413a000 fffff880`0416a000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
    fffff880`05400000 fffff880`05453000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
    fffff880`02a09000 fffff880`02a2f000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
    fffff880`00f60000 fffff880`00f75000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
    fffff880`00f2d000 fffff880`00f60000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`00fe6000 fffff880`00fed000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
    fffff880`00fed000 fffff880`00ffd000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
    fffff880`013d8000 fffff880`013e9000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
    fffff880`05453000 fffff880`054f9000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
    fffff880`0558a000 fffff880`055c7000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
    fffff880`00cd2000 fffff880`00ce6000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
    fffff880`042f5000 fffff880`04319000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
    fffff880`04354000 fffff880`0436f000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
    fffff880`0436f000 fffff880`04390000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
    fffff880`04390000 fffff880`043aa000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
    fffff880`03ca3000 fffff880`03cf4000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
    fffff880`043aa000 fffff880`043b5000   rdpbus   rdpbus.sys   Mon Jul 13 20:17:46 2009 (4A5BCEAA)
    fffff880`02ace000 fffff880`02ad7000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02ad7000 fffff880`02ae0000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
    fffff880`02ae0000 fffff880`02ae9000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
    fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
    fffff880`0686c000 fffff880`06884000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
    fffff880`04278000 fffff880`042cf000   Rt64win7 Rt64win7.sys Fri Sep 03 01:58:32 2010 (4C808E88)
    fffff880`06898000 fffff880`06ae4f80   RTKVHD64 RTKVHD64.sys Tue Jul 06 06:05:16 2010 (4C32FFDC)
    fffff880`03d0b000 fffff880`03d140a0   S3DInjectionDriver S3DInjectionDriver.sys Fri Apr 24 15:37:38 2009 (49F21502)
    fffff880`0423d000 fffff880`0426c000   SCSIPORT SCSIPORT.SYS Mon Jul 13 20:01:04 2009 (4A5BCAC0)
    fffff880`04400000 fffff880`0440b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
    fffff880`041eb000 fffff880`041f7000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
    fffff880`03c57000 fffff880`03c74000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
    fffff880`0148b000 fffff880`01493000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
    fffff880`06000000 fffff880`06071000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
    fffff880`06101000 fffff880`06197000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
    fffff880`0609a000 fffff880`06101000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
    fffff880`0440b000 fffff880`04438000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
    fffff880`0426c000 fffff880`0426d480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
    fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
    fffff880`04438000 fffff880`0444a000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
    fffff880`02b23000 fffff880`02b30000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
    fffff880`02b05000 fffff880`02b23000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
    fffff880`03c8f000 fffff880`03ca3000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
    fffff960`00480000 fffff960`0048a000   TSDDD    TSDDD.dll    unavailable (00000000)
    fffff880`03dd6000 fffff880`03dfc000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
    fffff880`043c4000 fffff880`043d6000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
    fffff880`06b44000 fffff880`06b61000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
    fffff880`0416a000 fffff880`0416bf00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
    fffff880`041da000 fffff880`041eb000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
    fffff880`0416c000 fffff880`04179000   usbfilter usbfilter.sys Tue Dec 22 03:26:22 2009 (4B3082AE)
    fffff880`054fb000 fffff880`05555000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
    fffff880`04179000 fffff880`04184000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
    fffff880`04184000 fffff880`041da000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
    fffff880`00f20000 fffff880`00f2d000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
    fffff880`02a8b000 fffff880`02a99000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
    fffff880`02a99000 fffff880`02abe000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
    fffff880`015ef000 fffff880`015ff000   vmstorfl vmstorfl.sys Mon Jul 13 19:42:54 2009 (4A5BC67E)
    fffff880`00f75000 fffff880`00f8a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
    fffff880`00f8a000 fffff880`00fe6000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
    fffff880`011ae000 fffff880`011fa000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
    fffff880`0412d000 fffff880`0413a000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
    fffff880`03c32000 fffff880`03c48000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
    fffff880`03c74000 fffff880`03c8f000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
    fffff880`02abe000 fffff880`02ace000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
    fffff880`00d44000 fffff880`00de8000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
    fffff880`00de8000 fffff880`00df7000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
    fffff880`02a00000 fffff880`02a09000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
    fffff960`000f0000 fffff960`003ff000   win32k   win32k.sys   Tue Aug 31 22:58:04 2010 (4C7DC13C)
    fffff880`00f0d000 fffff880`00f16000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
    fffff880`06823000 fffff880`06844000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
    Unloaded modules:
    fffff880`010a4000 fffff880`010b2000   crashdmp.sys
        Timestamp: unavailable (00000000)
        Checksum:  00000000
    fffff880`010b2000 fffff880`010be000   dump_ataport
        Checksum:  00000000
    fffff880`010be000 fffff880`010c7000   dump_atapi.s
        Checksum:  00000000
    fffff880`02a3e000 fffff880`02a51000   dump_dumpfve
        Checksum:  00000000
