BSOD while running on battery power
  1. Posts : 3
    Windows 7 Professional x64
    I would really like some help resolving my BSOD problem. I have experienced it several times now while running on battery but today it occurred while I was connected to power. I run blue screen viewer and it identified the broadcom driver as the main cause. Have tried reinstalling it twice now but no avail.
    I have attached the results from the SF diagnostics tool.
    Please help. I'm at the end of my wits here. tried everything I could think of except a reinstall of windows.
  2. Posts : 12,364
    8 Pro x64
    Yep, it's the broadcom driver all right.
    Have you tried the broadcom site for the latest driver:
    Determining the Correct Driver for Broadcom Ethernet Products | Broadcom
    That should help you identify and download the latest driver for your braodcom device.
  3. Posts : 3
    Thanks for the response smarteyball, I have already tried that before but I guess it won't hurt to try again. Hopefully this time my BSOD issue goes away.
  4. Posts : 12,364
    8 Pro x64
    Hopefully it is just software based and not a sign that the wireless card/chip itself is on it's way out.
    (Do you have problems with it dropping out etc?)
  5. Posts : 3
    No problems with drop outs at all. Works really well. Spoke to a tech guy and he suggested that it might be a problem with the power regulator for the wireless card. It seems to be running fine for now but it worked for a week last time i reinstalled the driver then BSOD again. Will just have to wait and see.
    Thanks for the help smarteyball
  6. Posts : 12,364
    8 Pro x64
    No worries mate. Fingers crossed.
