Solved PC will not wake up from 'power save' mode
juice
11:51 AM
My PC will tend to not wake up when it has been idle for maybe 30mins plus. My screen is set to turn off after 10mins, when I try to wake it up nothing happens basically, but the HDD (SSD) light is normally blinking.
My power save options are all set to Windows 7 default apart from:
  • Changed 'Turn off display' to '10mins'
  • Changed 'Put the computer to sleep' to 'Never'
  • Changed 'Turn off hard disk' to 'Never'
Thanks for the help, SF diagnostic files are attached.
Microsoft Windows 7 Professional 64-bit 7601 ...Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz16.00 GBEVGA GeForce GTX 660 Ti SC 2GB GDDR5
MSI Z77A-GD55 (MS-7751)
16.00 GB
Dell Ultrasharp 23in 1920x1080
(1) MKNSSDCR240GB ATA Device (2) SAMSUNG HD501LJ ATA Device (3) WD 5000AAV External USB Device
630W be quiet! PURE POWER CM L8-CM 80PLUS
Mid Tower
1x intake 1x exhaust
Microsoft
Kinzu V2
30mb
Microsoft
Hello there!
Try these articles
Can't exit power saving mode
Computer Will Not Wake up From Power Saving Mode Sleep | Computer Tips
Also I would be a good choice to update the Display drivers. Check this article to know how to update the Drivers : How to Update Drivers on Windows 7 | Captain Debugger
Windows 7 Ultimate - 64-bit | Windows 8 Pro -...Intel® Core™ i7 Processor 3,610QM (2.30Hz, 6M...8 GBNVIDIA® GeForce® GT 650M 2GB Graphics, Optimu...
Samsung NP550P5C-S02IN
Intel® Core™ i7 Processor 3,610QM (2.30Hz, 6MB L3 Cach
8 GB
NVIDIA® GeForce® GT 650M 2GB Graphics, Optimus™ techno
SoundAlive™ JBL 3 Speakers (With sub-Woofer)
39.62cm (15.6) SuperBright 300nit HD+ LED Display
1,600 x 900, Anti-Reflective
1TB S-ATA II Hard Drive (5,400RPM)
My display drivers are definitely up to date (my AMD gfx card has a driver update checker) and I'm pretty sure my mobo battery is not dead as it's only a few months old!
16.00 GB
Mid Tower
Microsoft
Kinzu V2
30mb
Microsoft
