Sorry for the late response Been rather sick for the past few days. But I had a look through your files and if you could please do the following:
Enable
driver verifier and allow it to crash your computer, if it has not crashed within 24 hours move on to the next step:
Driver Verifier - Enable and Disable
Tip: If you can not boot normally into windows after enabling Driver Verifier please boot into safe mode and then disable driver verifier.
If Driver verifier does not cause a crash after 24 hours please run memtest86+ for at least 8 passes:
RAM - Test with Memtest86+
Tip: Do this over night it can take a long time
