Windows 7: Strange freezing problem and administrator problem
08 Oct 2009   #1
Atza
Windows 7 Ultimate 64bit
Hi all, I'm new on the forums. Best Windows 7 forums btw, have helped me a lot.
So I'm having two different or same kind of problems. I really need help to solve these!
Problem number one:
I'm having a strange freezing problem. Sometimes randomly my desktop freezes. I can't right-click any icons, remove icons or do anything for them. To solve this problem every time I need to reboot or log off and log in again. Then Sometimes my explorer.exe -process dies randomly and same kind of problem appears. Any fixes?
Problem number two:
I'm the system administrator, but sometimes randomly I don't have an access to change some directories or files. Sometimes if I download a file, I can't save it to the desktop. What is this all about and how I can solve this?
Specs:
CPU: Intel Core 2 Duo E8500 @ 4,4GHz
Mainboard: Asus P5Q Pro
GFX: Sapphire ATI Radeon HD 4850 Mb
Memory: 4 Gb Exceleram DDR2 1110MHz
Soundcard: Creative Sound Blaster X-Fi XtremeGamer
Storage: ~1 Tb
OS: Windows 7 Ultimate OEM 64bit newest version
Everything else works fine still, but these are two annoying problems I'm facing.
Thanks, xoxo
08 Oct 2009   #2
Solace
Windows 7 7600 x64/x32
ur second problem is caused by the application experience service not running. by having that disables you will get that permissions error after you navigate into any newly created folder. if this is not the issue then something else has altered your permissions
08 Oct 2009   #3
zigzag3143
Win 8 Release candidate 8400
Atza
Hi and welcome to sevenforums
First I wanted to say thanks for filling in your system specs they really help.
Lets tackle the first problem. can you go into event viewer (type event viewer in search) go to the windows logs, application tab. Look for errors (red "X" in left column) that relate to explorer, or any application stopping. If explorer is there (and it will be) use the built in snipping tool (type snipping in search) to take a screenshot of the event and upload it to us using the attachment icon (shaped like a paperclip) in the reply form
Thanks again and let us know if y ou need help with any of this
Ken
08 Oct 2009   #4
DarkXeno
• CPU: Intel Core 2 Duo E8500 @ 4,4GHz
Im going to take three shots in the dark.
1) your overclocking reset it back to defaults and test the system
2) it could be a heat issue.
3) you don't list a power supply wattage.
08 Oct 2009   #5
chev65
Lets see here, E8500 at 4.4 GHz with some off brand Ram running at 1110MHz and you are wondering why you are getting freeze ups?
Unless your substantial overclock has been stablity tested to the max with Prime Blend, linux, OCCT you can't say that this problem isn't related to unstable overclocking which I'am sure is the case here.
I'd say problem number one here is that your overclock is not completely stable.
Suggest you fire up Prime 95 and see how long you can run the Blend test for.
08 Oct 2009   #6
Atza
Quote   Quote: Originally Posted by chev65 View Post
Its not a totally freeze-up. I can do anything else, but desktop is freezing somehow.
08 Oct 2009   #7
Atza
Quote   Quote: Originally Posted by DarkXeno View Post
I've got a good power supply, it isn't the problem. Also my temperatures are 25 degress idle and under maximum testing still cool. So it isn't a heat issue too.
08 Oct 2009   #8
zigzag3143
atza
And event viewer?
08 Oct 2009   #9
Atza
Quote   Quote: Originally Posted by Solace View Post
It was disabled, lets see what happens now when it is enabled. Thanks for the advice.
08 Oct 2009   #10
Atza
Quote   Quote: Originally Posted by zigzag3143 View Post
atza
And event viewer?
checking up now
Strange Freezing Problem, assistance needed...
Hello everyone I just joined this forum for this specific problem and I've read through some of your threads and everyone seems very helpful so I'm glad to be a part of your group. I did search the forum and tried some solutions suggested but had no luck. I bought my laptop about 5 months...
General Discussion
Administrator Problem
Have a new personal ThinkPad with Windows 7. Tried to set up Normal.dot in Word and was directed to Documents and Settings, but found it had become hidden (I had seen it in a prior session). When I typed in the name, I was told it was available only to the Administrator - which of course is me. ...
General Discussion
System administrator problem
Hi, I have tried to install a program (inksave) and got this message" Windows installer" "The system administrator has set policies to prevent this installation" I am the only user on my PC so I am the administrator. can anyone advise please regards
General Discussion
Administrator account problem
Hi peeps, I'm new here so bare with me! The reason I'm posting is that for the last few months I've been having a problem (and ignoring it) but I can't stand it anymore! Every time I log in to any account on my laptop (including administrator) the desktop comes up with a pop-up message...
General Discussion
Administrator problem
I am running Windows 7 and I have done many clean installs over the years so I feel pretty comfortable with it. For some reason, on the most recent install, I cannot open the Documents and Settings folder. Now, I've always been able to open this folder by doing all the Admin tricks available...
General Discussion
OK this is the problem: I have 2 accounts on my computer, one has admin privilages and one is a regular account. I used regedit to hide the administrator account on the log in screen. But in order to un hide the admin account you have to use regedit again, but in order to change anything in the...
General Discussion
