Need Help to figure out my BSOD problem.
Page 2 of 12 FirstFirst 1234 ... LastLast
  1. Posts : 47
    Windows 7 Ultimate x86
    I've been running the Memtest all night long, 0 errors..
    And it has passed more than 10 passes.
  2. Posts : 11,990
    Windows 7 Ultimate 32 bit
       #12
    The dumps are still pointing to hardware issues; but, at least, you have eliminated memory. The error codes still point to memory corruption; but that does not necessarily mean your RAM is bad. Driver conflicts, for example, can cause memory corruption.
    In the first dump, Windows Media Player Sharing was running at the time of the crash; in the second, Itunes Helper was running, in the third, Firefox; and in the latest dump, Skype was running.
    STOP 0x0000008E: KERNEL_MODE_EXCEPTION_NOT_HANDLED
    Usual causes: Insufficient disk space, Device driver, Video card, BIOS, Breakpoint in startup without having a debugger attached, Hardware incompatibility, Faulty system service, 3rd party remote control, Memory
    STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
    Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility
    STOP 0x00000050: PAGE_FAULT_IN_NONPAGED_AREA
    Usual causes: Defective hardware (particularly memory - but not just RAM), Faulty system service, Antivirus, Device driver, NTFS corruption, BIOS
    STOP 0x0000001A: MEMORY_MANAGEMENT
    Usual causes: Device driver, memory, kernel
    What antivirus program are you using and what firewall are you running?
  3. Posts : 47
    I am running Eset NOD32 Antivirus. And about the firewall, I'm pretty sure that is the standard one.
  4. Posts : 1,598
    Microsoft Window 7 Professional 32 bit
       #14
    Hi emperact
    Third party anti-virus program are notorious cause for bsods and yours is not exception. Would you be willing to uninstall your anti-virus program just for testing purpose only!!! you can always re-install it if it's not the cause
    Let us know how it goes
    Tuan
  5. Posts : 47
       #15
    Of course, I'll try it right away. But isn't my computer then exposed for virus and malware etc?
  6. Posts : 17,796
       #16
    Welcome
    You can install MSE, Microsoft Security Essentials. As a side note, I suggest that you keep and use that rather than your present anti Virus.
    http://www.microsoft.com/Security_Essentials/
    Made specifically for windows, free, and known not to cause BSOD
    If you want to keep your own, start with a system restore point.
    How you doing, TTran?
  7. Posts : 11,840
    64-bit Windows 8.1 Pro
       #17
    Install Microsoft Security Essentials .. its free and does an excellent job, then see if your computer still crashes.. MSE Download
  8. Posts : 11,990
       #18
    The advice from ttran, rich, and Tews is spot on. That is why I asked the question about your antivirus program. Eset is known to cause crashes on some systems. Try running without it (using MSE) and see if that eliminates the problem.
  9. Posts : 47
       #19
    Thank you guys, I'll try it right away. The funny thing is, that after I took the Memtest, I haven't had a BSOD since 2 days ago. But I will try the MSE.
  10. Posts : 17,796
       #20
    The best part of MSE, since it was made specifically for Windows, by Microsoft, it has not been the cause of one BSOD that I have seen, its free and works great.
