Windows 7: Will this cable work to extend coaxial cable for cable box?
14 Aug 2012   #1
XGamer95
Windows 7 Ultimate 64-bit
Getting a new TV and placing it in a different spot than where the old TV is and I realized the coaxial cable coming from the wall isn't going to reach the new location for cable box's "Cable IN" connection. Can I use this as an extension? It looks right to me but I just want to be sure.
14 Aug 2012   #2
derekimo
Quote   Quote: Originally Posted by XGamer95 View Post
All you need is one of these,
And another piece of coax.
14 Aug 2012   #3
thefabe
Like Derekimo has stated but more simply Yes the one you pictured has everything you'll need.
Fabe
14 Aug 2012   #4
Sardonicus
Windows 7 Home Premium 64 bit
Don't use the cable in your link. Cable companies use RG-6 Cable (not RG-58).
Newegg.com - RCA Model VH606 6 ft Basic Series Digital RG6 Coaxial Cable in Black Color
14 Aug 2012   #5
Sardonicus
Plus the cable coupler Derekimo mentioned.
Difference between Audio Cable and Aux Cable
Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well....
How do I get my Viewcon MIDI to USB cable to work?
Like a lot of people I bought a cheap generic brand MIDI interface on Amazon so I could connect my Yamaha PSR-275 Keyboard to my Windows 7 64bit Laptop. I tried many things including downloading xmidi, rimio, and Yamaha drivers, but bone worked. With the romio driver output on my pc works on my...
Drivers
Can I use a Y-splitter printer cable? Do they work?
I was looking at this cable and I know it doesn't work because the red connector only carries power and no data. Is there a Y-splitter printer cable that will work? I don't want to buy a print router because my workload does not require one and if a y-splitter doesn't work will this hub work?
Hardware & Devices
Digital Cable Advisor fails, can't install cable card. . . why?
http://img198.imageshack.us/img198/83/cableadvisor.png Uploaded with ImageShack.us http://img51.imageshack.us/img51/4821/playreadfail.png Uploaded with ImageShack.us HD Radeon 6870 Graphics card
Media Center
Network Cable Unplugged error: cable is plugged in
Hello, Since last night, my LAN connection has been giving me the error "Network cable unplugged." I have tried swapping the cable with another, swapping the ports on the router, restarting the router, power cycling the router, turning off the router and my computer and then turning them back...
Network & Sharing
Network cable unplugged message when using ethernet cable
Hi, I have a brand new Dell Precision Workstation with Windows 7 Professional 64 bit. I have not been able to connect to networks or the internet. It does not recognize that it is plugged into the network/internet via an ethernet cable. The computer has a Broadcom NetLink Gigabit Ethernet adapter...
Network & Sharing
