Using I change to Battery Power my desktop screen changes
nlchamps
4:09 PM
Hi I just purchased A New ASUS notebook and every time I switch to battery power my laptop (Background) changes.. I would like to know how to stop this??
THanks
WINDOWS 7 64intel core I34GBATI RADEON HD 5470
asus k52jr
WINDOWS 7 64
intel core I3
4GB
ATI RADEON HD 5470
640GB
Cable
When you unplug your notebook, the desktop wallpaper changes?
Windows 7 UltimateAMD Athlon II X2 245 2.90Ghz3.00 GB8800GTS 512MB
Windows 7 Ultimate
Some Gigabyte one, dont remember model
3.00 GB
8800GTS 512MB
Sound Blaster X-Fi Titanium Fatal1ty
Dual 22" widescreen
250GB internal, 500GB internal
CORSAIR CMPSU-850TX 850W Power Supply
Thermalkake Tsunami Dream
Thermaltake Golden Orb II
Saitek Eclipse 2
Logitech MX518
Yes, that is correct and I want to know how to stop that??
asus k52jr
WINDOWS 7 64
intel core I3
4GB
ATI RADEON HD 5470
640GB
Cable
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
Do you use the a slideshow background?
Windows 7 Professional SP1 64-bitIntel Core i5-2450M @2.5 GHz6 GB DDR3 1333MHzIntel HD 3000
Toshiba P775-S7100
6 GB DDR3 1333MHz
Intel HD 3000
Built-in 17.3" LED; 22" Insignia NS-L22Q-10A
1600x900; 1360x768
750 GB Hitachi
1TB Seagate FreeAgent External
Verizon DSL Speed(Down/Up): 3360 Kbps / 800 Kbps
MSE and MBAM Pro
IE10
It's built into Asus's bloatware. When you change the power management type, it'll change as well I take it? It does this on my Asus laptop; you just have to change the settings to use a different theme then the one you are using.
Windows 7 Ultimate x64Intel Core 2 Duo 2.5ghzPNY 4GB DDR2 800MSI 9600GT
Me
ECS G43T-M
PNY 4GB DDR2 800
MSI 9600GT
2x Asus VW266H
320gb Samsung Spinpoint F1 7200rpm
300gb Western Digital Black Caviar 7200 RPM
Corsair 750W
Rosewill
Silenx Fans
Microsoft Digital Media 3000
Logitech LX8
Thank you Surban Atlas it was the Asus bloatware causing the problem.. Also thank you to everyone for there help with this...
asus k52jr
WINDOWS 7 64
intel core I3
4GB
ATI RADEON HD 5470
640GB
Cable
Glad you figured it out. Bloatware can cause all kinds of strange behavior.
Toshiba P775-S7100
6 GB DDR3 1333MHz
Intel HD 3000
1600x900; 1360x768
750 GB Hitachi
MSE and MBAM Pro
IE10
I know this thread is outdated, but perhaps this reply will help others in the future.
I had this exact issue and was looking into it. I understand that it's due to ASUS's pre-installed software - the ASUS Power4Gear Hybrid application, to be exact - but I actually do like the software, so I'm keeping it.
However, if you have an issue with the desktop changing when the laptop is unplugged, you can do this:
1) Go to your laptop's Power Options (in the system tray located in the bottom right corner, click on the battery icon)
2) Click on the "More power options" link
3) Click on the "Change plan settings" link for Power4Gear Battery Saving
4) Click on the "Change advanced power settings" link
5) Locate "ASUS P4G Power Setting" and click on the + sign
6) Locate "Battery Saving Desktop" and click on the + sign
7) Next to "On battery," select "Disable"
8) Click the Apply button, click the OK button, then close all the windows you opened
Now when you unplug your laptop, it should no longer change the desktop settings.
Hope this helps!
Vic
Windows 7 ProfessionalIntel Core2Duo T52703072MBnVidia GeForce 8400M GS
Dell Vostro 1500
3072MB
Western Digital 320GB Scorpio Blue SATAII
Logitech VX Revolution
Comcast Performance High Speed Internet
