Little 2 Problems needs hElp!
  1. Posts : 86
    WIN 7 x64
    I have a little problem which is really annoying...i have Rocketdock skin that supose to have different application indicator then just black but my Rocketdock after reinstalling it million times still does only shows the black indicator...
    really annoying!
    here's screenshot to show that...
    second problem
    it never shows the minimized windows...on dock rather it minimizes them on taskbar :/
    anyways to minimize the windows on top of Rocketdock?
    Thanks for all the help folks!
  2. Posts : 86
    WIN 7 x64
    20 views....no help plz :) Bump!
  3. Posts : 2,963
    Found this using Google (go figure): How to change icons in rocketdock? - General Discussion - Windows Customization & Support - FORUM CrystalXP.net English
    What version of RocketDock are you using? None of the pictures I have seen look like yours.
    Also, 20 views is not a lot. Also, take a look at the forum rules, via the Quick Links link at the top of the page.
  4. Posts : 86
    WIN 7 x64
    ok Petey7...i completly forgot this was not one of my gaming forums...sorry for bumping...
    and i am using 1.3.5
    and i want to make my dock something like this in manner of indicator!
  5. Posts : 2,963
    From what I have read (I have not actually used rocket dock, as I find it redundant with the new taskbar, but to each his own) RocketDock should let you minimize programs directly to it. This is not to say that it will not still appear on the taskbar, but that you can maximize/restore the program from rocketdock. Perhaps the skin you are using is causing the problem.
  6. Posts : 86
    WIN 7 x64
    also the indicator never seems to change from black arrow?//// and if anyone can suggest replacement for a dock that has stacks...and has skins...and no fixed location require by software like XWindows Does!
    i would be happy camper!
