More than two power schemes?
  1. Posts : 13
    Windows 7 Ultimate 32bit
    Hey i just wanted to know any way to increase the number of options for selecting power schemes in the system tray power icon(battery). Currently there are 2
    (in my case 1.Power Saver 2.Balanced)
    Can i add another one here itself(ex: 3.High Performance)? coz opening the power customization windows every time is cubersome (though it allows to select any of the schemes thereafter)
    <Remember Vista ? we had these 3 options by default powersaver,balanced and highperformance when we clicked the system tray icon
    maybe a registry edit could do the trick but i dunno much>
    thankx for any help
  2. Posts : 14
    +1 for your question.
    I've only known batch line operation exists. (plus custom hotkey maybe)
    After research, I come up with FlyoutAutoPowerScheme. But don't know how to implement it.
    (ref: See all 3 power plans on system tray - Microsoft Answers)
    Software such as "Power Plan Assistant", "Power Scheme Switcher", "SchemeHK", "Total Power Control" can also perform the job.
  3. Posts : 13
    Windows 7 Home Premium
    This is a very good question. I registered here only to ask this question and after quick search, it seems like I'm not the only one wanting this.
    My laptop has 6 schemes in total (I have Czech language windows, so sorry for rough translation)
    Power saving scheme
    Balance
    High performance
    Ecological (I suspect that Toshiba drivers put this one here)
    I also created two more
    Power saving STEALTH (lowest performance, as less fan speed as possible)
    & Gaming MAX (everything high, including fan)
    So, when I click on battery icon in systray, I have just two there. For more of them, I have to click on "more" and then wait a second or two before this window loads, then select what I want and then close the window.
    Seems like too much unnecessary steps to me. So if anyone knows how to do it, I'm all for it.
    Going to search registry for some values about it.
  4. Posts : 72,052
    Hello Marty, and welcome to Seven Forums.
    As a workaround, you could use the tutorial below to create shortcuts that will allow you to change or switch to the High Performance, Balanced, Power Saver, or a custom power plan instantly without having to go through Power Options in the Control Panel.
    Power Plan - Create Shortcut to Change Power Plan
  5. Posts : 13
    Thanks Shawn for warm welcome, as I plan to use Win 7 for next few years (and also to use notebooks), I'll try your suggestion and also these apps of previous poster, to find the path that will suit me best.
    As a matter of fact, I would like to ask related question. I don't quite feel like starting new thread, because it's very connected to this topic, so:
    Question moved to: I cannot find a right scheme to fit my needs
  6. Posts : 72,052
    You're welcome Marty. I hope it works out for you.
    Your other question is going to involve BIOS settings and possibly a 3rd party or OEM program to monitor and adjust fan speeds. This should be posted in a new thread since it's not going to be related to Power Plan Scheme, so I moved that question to the link below so that you can get better help with it.
  7. Posts : 13
    OK, I suppose it's part of my learning curve, these little distinctions between forum boards all over the internet, their policies, culture etc.
    So on topic - I've tried PowerSwitch app and so far, it's going well. The only problem is that I seem to be unable to choose "AUTO" selection. It's gray and cannot be selected, while schemes can.
  8. Posts : 72,052
    Marty,
    I'm happy to hear that it'll work for you so far. I hope you get a solution at the other link soon.
