Problem changing or restoring logon screen - Help plz !
  1. Posts : 40
    Windows 7 Ultimate (Alienware) x32
    I tried resizing an jpg with Paint to use it as logon screen and before to save it a message showed saying that i will lose the transparency of the file but I save it and applied anyway.
    My mistake cause since then, whatever I tried, I can't restore or replace that ugly thing that I created. I used "Windows 7 Logon Background Changer 1.5.2" , I did it manually by editing the registry but always the same thing, background changes but the white small window from the center it's always there and I can't get rid of it !
    Is there any way to restore or change that ?
    Thanks ... I would like to to attach a screenshot but I don't know how !
    Help please !
  2. Posts : 81
    Windows 7 Home Premium SP1, 64 bit
    See this tutorial to learn to attatch pictures.
    If you have the OS seperate from your main files you can simply reinstall windows.
  3. Posts : 40
    To reinstall windows it's the only way? And I tried to take a screenshot of the image but I can't do it, pressing Alt+Ctrl+Del to get to the Logon screen ... Paint doesnt work there ... and again, reinstalling the windows its the only solution?
  4. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    No reinstall is needed. Use a system restore point to before you messed up the logon screen. System Restore
    You can't take a snip of the logon screen, you need to take a pic of it with a camera.
    Then upload it per the tutorial.
  5. Posts : 40
    Ok Britton30, I'll use that, thanks and all the best !
  6. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
    You could also try Option 2 of this tutorial SFC /SCANNOW Command - System File Checker it will not harm any data or programs you have installed it will try to find and repair any corrupt system files that you have. You may need to do this up to 3 times with a reboot after each scan.
    Jerry
  7. Posts : 40
    Thanks for answering Bongo !
  8. Posts : 5,956
    Win 7 Pro x64, Win 10 Pro x64, Linux Light x86
    Hi cristy73
    Go System Restore > System Restore
  9. Posts : 12,120
    You're Welcome
    Did it fix your problem?
  10. Posts : 40
    So ... that's good now, I tried run "System Restore" but I couldnt find any restore point even if I know I had 2 or 3 of them, so I did run "sfc /runnow" 3 times with restart after each one so all it's good now, I can handle it from here !
    Thanks a lot to everyone who answered, this is the best "Windows 7 Help" forum, but I'm sure you all knows it by now.
    Thanks again and all the best everyone !!!
