Transparency for tray, battery, lan, sound, clock, etc.
  1. Posts : 12
    Hi, guys! I wonder, if it's possible to make those menus transparent?..
    I'm already using Chameleon 2 theme with BlackGlassEnhanced v.0.5 and Moo0 Transparent Menu v.1.20
    Attached Thumbnails Attached Thumbnails Transparency for tray, battery, lan, sound, clock, etc.-unnamed1.png   Transparency for tray, battery, lan, sound, clock, etc.-unnamed2.png   Transparency for tray, battery, lan, sound, clock, etc.-unnamed3.png
  2. Posts : 1,872
    Windows 10 Pro x64, Windows 8.1 Pro x64, Windows 7 Ultimate x64 SP1,
    Not that I am aware of.
  3. Posts : 53,365
    Windows 10 Home x64
    Welcome to Seven Forums Schumacher92. This should make the taskbar and the icons transparent. See if it suits you.
    Fade.Taskbar 2.0 by Ritwyk on deviantART
    A Guy
  4. Posts : 12
    Yeah... But I don't need the taskbar to be transparent. I want the background of those tray menus be transparent (which are gray atm)...
  5. Posts : 53,365
    Windows 10 Home x64
    All the things I could find make the taskbar transparent, and the icons as a byproduct. People were wanting transparent taskbar with normal icons. No luck finding just transparent icons. I assumed since you were using Chameleon, and glass, you were going for that looks. A Guy
  6. Posts : 12
    W8ing for Bongo here. Windows Style Builder expert is required...
  7. Posts : 53,365
    Windows 10 Home x64
    Jerry (Bongo) has been away for a while with health issues. Not sure when he will be back. A Guy
