Greetings,
As most of you probably know removing unwanted Fonts can greatly speed up the system. I'm using Windows 7 and would like some advice as to which Fonts I should remove.
Actually I don't plan on removing them, all I want to do is move them to another location, out of the Fonts folder.
If I can squeeze every tweak in order to improve my system performance then I'm on it !
Thoughts and advice ?
Jordan
Jordan
Windows 7 baby ! : DIntel Core i7 720QM @ 1.60GHz6.0GB Dual-Channel DDR3 @ 662MHzATI Mobility Radeon HD 5650
- HP Envy 17 4054ca
- Windows 7 baby ! : D
- Intel Core i7 720QM @ 1.60GHz
- Motherboard
- Hewlett-Packard 1449 (CPU)
- 6.0GB Dual-Channel DDR3 @ 662MHz
- Graphics Card(s)
- ATI Mobility Radeon HD 5650
- Sound Card
- IDT High Definition Audio CODEC
- Monitor(s) Displays
- Generic PnP Monitor @ 1600x900
- Screen Resolution
- 1600X900
- Hard Drives
- 78.15GB INTEL SSDSA2M080G2GC ATA Device (IDE)
