Windows 7: Twinhan DVB card driver works in Vista 64bit but not 7 64bit HELP HELP
19 Sep 2010   #1
medorpg
Windows 7 Ultimate 64bit
Hello
I have a DVB card called Twinhan 1025
Twinhan company is gone so they dont provide new drivers
the driver we have is for Vista 64bit which works well with RAM more or less than 4 GB but in Windows 7 64bit it works with only RAM less than 4 GB
My RAM is 6 GB when I boot normally I am able to get the signal level and quality but cant add channels or view them
when I set the boot option the limits the memory to 4000MB I am able to view or add new channels
This is not a software issue
cause I have tried programs in compatibility mode and as administrator
and download viewers for 64bit OS and for 32 bit OS
So it's a driver problem or Windows 7 problem
Now can I do something to make Windows allow this driver to map specific range of memory ?
Please help with any solution cause the workaround of limiting the boot memory isn't a practical one
I even tried to install VM's and install Windows XP but they do not provide access to PCI slots
19 Sep 2010   #2
medorpg
Up!
29 Sep 2010   #3
medorpg
up!
Windows 7 64Bit Driver issues for the Radeon HD6770M Video Card
I was wondering if anyone could help me with this issue I am having. I have a HP Pavilion Dv7 laptop with a Radeon HD6770M Video card and when I installed the initial drivers after doing a factory restore on my laptop the video card showed the HD6770M in the device manager. Once I updated the...
Graphic Cards
No Audio device - Code 52 - can't find a driver that works 64bit
PC shows no audio device in system tray, Device Manager shows two devices with yellow explanation marks - Code 52 error. Driver details shows default Microsoft drivers in use. Various driver installs attempted. Machine updated from Vista. "Windows cannot verify the digital signature for the...
Drivers
Unsigned driver installs and works on W7 64bit OS, why?
I've been running around trying to get our drivers certified because I'm told all over the internet that they won't work on W7 64 bit OS because they are not signed/certified. I just watched a guy install them on his W7 PRO 64 bit machine and the only problem he had was the conventional "this...
Drivers
No 32-bit browser works, but IE8 64bit does
Somehow in the last week Win7 stopped being able to run Firefox, Chrome or IE8 (32bit) browsers; however, IE8 x64 version runs just fine. I've done all kinds of Network troubleshooting but everything there seems to be fine. I also took the suggestion to reset the IE8 settings but that didn't...
Browsers & Mail
cubase SX works on RTM 64BIT??
i have cubase SX and i want to install win 7 RTM 64BIT anyone here working with this program and works ok on 64BIT?
Software
nForce driver sets 15.46 for Vista+Win7 (32/64bit)
Ethernet Driver (v73.10) customized by Fernando SATAIDE Driver (v11.1.0.30) customized by Fernando SATARAID Driver (v11.1.0.30) customized by Fernando RAIDTOOL Application (v11.1.0.30) "Sedona" SMU Driver (v1.71) WHQL SMBus Driver (v4.71) customized by Fernando HD Audio Driver...
Drivers
