Root Enumerator problem...HELP!HELP!
  1. Posts : 5
    hello all, i have a slight problem....when i go to "Devices and Printers" on the devices section, it has my laptop there, with a little triangle sign on the bottom right that says "needs trouble shooting"; so i did. after troubleshooting, it says that i need to download Root Enumerator, but when i try to download it, it fails. Does this have anything to do with the fact that my keyboard stops working sometimes, and only types these: []. How can i download it?!?!? PLease help!
  2. Posts : 6,243
    Hi tinskullboy,Welcome to the forums, can I point you to this thread how to install UMBus Root Bus Enumerator post#3 :)
  3. Posts : 5
    Thank you sooo much! i love you!!! do you know if it has anything to do with my keyboard? and how did it get deleted?
  4. Posts : 6,243
    Hi tinskullboy, It could be any number of reasons , How old is the laptop, make manf ?,When did you last clean it ?
  5. Posts : 5
    i haven't ever cleaned it, but it quit doing it....that enumerator thing didnt solve the problem, is it really that necessary to have? it's not affecting the performance of my computer, so i have no idea....
  6. Posts : 6,243
    tinskullboy , If it is'nt causing a problem you may as well forget about it , but do try cleaning the inlet and exhaust ports of your laptop, A can of compressed air blown into and around the ports will prevent dust and heat build ups and help to extend the life of your lappy :)
  7. Posts : 5
    Thanks for the help! It really means a lot!
  8. Posts : 6,243
    You're very welcome tinskullboy :)
  9. Posts : 5
    Just cleaned out my fan and my keyboard...WOW!!! at least half a truckload of dust came out of my fan, and a whole dog of hair came out of my keyboard! no more keyboard problems! Thanks!
