USB 3.0 HUB speed problem
Commodore Pet
Time Lord
2:17 AM
Gallifrey
I just purchased a Ultra Aluminous 4 port USB 3.0 Hub.
My computer has been relocated and it is now very difficult to get at my 3.0 ports on the back of the machine so I thought this would make life easy.:sarc:
My latest Renesas USB 3.0 driver software sees the new hub as USB 2.0 and installs that driver. I have 2 USB 3.0 drives that work fine if plugged directly into the back ports, but if I plug them into my new hub I get a message telling me they can go faster.
Is there a way to manually install the USB 3.0 hub driver? I believe the Renesas driver package includes it. I tried using device manager manual install but it does not list Renesas drivers when it lists all available drivers.
I have tried removing and re-installing the latest driver software with no luck.
Windows 7 Home Premium 64 bit SP1Intel i7 4790k16 GB Corsair 2400 MHz DDR3Visiontek Radeon R9 285
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Samsung 840 EVO 500GB
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
60.88 Mbps download 10.47 Mbps upload (Speedtest.net)
Norton
Opera
First Computer used: A Commodore Pet of course
Love using Manjaro KDE Linux 64 bit and Windows 7/10 64 bit
If this is not a self-powered hub, there may be a problem with the devices starving from power.
Have you looked at the manual or visited the manufacturer's website to see what they have to say about your issue. That might help. Also as whs hinted, if the item came with a power cord, is it hooked up?
Windows 10 ProIntel Core i7-4770K (3.5Ghz)32 gig Corsair Dominator Platinum (4x8Gig)Sapphire Tri-X R9 Fury
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
NEC PA242W 24" LCD Monitor
1920 x 1200
EVGA Supernova 1000 G2
Cooler Master HAF X
Logitech Wireless Wave
Logitech Performance MX
High Speed Cable
Norton Security
IE11
I have the hub plugged in to a live outlet.
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
No manual came with it, but I will do some digging around on the company website.
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
Let us know what you find out. The info could help others.
Thanks.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
I searched Ultra's website and had no luck. I also did several web searches and came up empty.:(
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
But as things are it definitely looks like a driver problem. I would call the company and ask them what they suggest.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
Then I would suggest you call Aluminous and find out what's going on. Good luck.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
Hello,
is your hub is plugged into the USB 3.0 ports on the back?
If not and you've plugged the hub into one of the USB 2.0 ports, then the hub will operate at 2.0 speeds.
Windows 7 Home Premium 64 bitIntel Core i7-4790G.SKILL 8GB (2 x 4GB) DDR3 F3-10666CL9D-8GBNTAMD Radeon R7 250
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
1920 x 1080, 1280 x 1024
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Samsung 128 GB 840 PRO
SeaSonic M12II SS-500GM
Fractal Design Define R4
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Hello,
I have tried both of my USB 3.0 ports
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
I have also updated to the latest driver and firmware that I can find.
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
Have you turned off the PC with the HUB on
and allowed Windows 7 to re-initialize after start-up?
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
I called Ultra tech support and they told me I had done everything they could think of and to just return it. I am hoping someone on this site will think of something I have missed. If not, by Wednesday, I will look into returning it.
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
Honestly looking through the post it looks like you've done everything you should have done. And if tech support can't give you any other advice, than yeah, return it.
Actually there is one question? Is you motherboard 3.0 compliant? You mention the renesis drivers so I assume it is, but I have to ask.... just in case.
Actually I just Googled it and it appears it is.
Custom built by me.
Windows 10 Pro
Soundblaster ZXR
1920 x 1200
Cooler Master HAF X
High Speed Cable
Norton Security
IE11
As long as you've plugged the hub into the Blue ports, then you've done all you can do.
Good luck.
Intel Core i7-4790
GA-Z87X-D3H
AMD Radeon R7 250
Realtek ALC892
WD5003AZEX
WD10EZEX
Samsung HD103SJ
Zalman CNPS9900ALED
Logitech K800
Logitech M705
16 Mbps
Hello sorry for my bad english.
You can try in win 7 32 bits and works ok. In 64 bits there are a problem a don´t work at 3.0 velocity.
Just belive me, i tried this in a second partition with 32 bits and works fine.
a lot of them
a lot of them
Thanks. I only have 64 bit installed but at least it gives me something to go on.
Intel i7 4790k
MSI Z97-G55 SLI
None
Gateway FHX2402L
1920 X 1080
Corsair 750 TX
Fractal Design
Stock fans
Logitech K800
Logitech M510
Norton
Opera
