Windows 7 Forums Search
Windows 7 - HELP 64bit modem adsl driver problem
08-02-2009   #1
Seven 64bit
i have a HAMLET HDSL640 USB MODEM ADSL and there are only drivers for 32bit that don't work with seven 64bit
there are no installation with these drivers, only the drivers that canět be installed on 64bit
there are solution or not?
08-02-2009   #2
Windows 7 Ultimate x64, XP Mode(VPC and VMLite), VM Player 4.02, W8 CPreview
Well welcome to the Se7enforums just the same! djsolidsnake86
You are going through the same dilemna I had some time back of never being able to get online with any Linux distro long before Vista even with an old dsl setup here. The last update for that was seen in 2002 for 98-XP compatibility. The ISP saw a change here fortunately before the Release Candidates were available since I have multiple 64bit installations!
The first place to start with the modem there is at the manufacturer's own support site to see they released any Vista 64bit updates. The old 32bit drivers for the dsl setup here worked on the 32bit 7 but not the 64bit. Even after going with a new ISP the modem they provided lacked 64bit drivers when looked into where a new one was bought separately! You may have to make a few changes due to these problems in order to get online with any 64bit Windows.
08-02-2009   #3
Seven 64bit
there are no new drivers on the site, only for xp 32 bit
i think that there are no solution
08-02-2009   #4
Win7 Build 7600 x86
Best advice I can give you is to buy an ethernet modem/router.
It's faster, it's safer, and it doesn't depend on any driver.
Further more you'll be able to login the modem/router and configure and tweak it exactely the way you want it.
And they are very cheap nowadays.
If you need help on finding a good one for little money, just yell.
greetz
08-03-2009   #5
That will depend on ISP's setup there. I went through all this stuff not too long ago when not being able to connect with the 64bit beta build until simply chenging ISPs entirely! Depending on the type of setup you may find yourself limited on options!
Even when swapping ISPs here the modem they provided was also "worthless"! That was also some older outdated piece of crap modem! GGrrrr.... I was able to look up "their list" of supported cable modems and get things going here due to the update type of connection.
Hopefully you can do the same there! Keep your fingers crossed.
08-03-2009   #6
Win7 Build 7600 x86
Quote   Quote: Originally Posted by Night Hawk View Post
Luckily he has ADSL. Any advanced modem/router will work.
ISP often provide limited crap, especially usb modems, but a linksys can handle any exotic setup.
The thing he has to check is if it's annex-a or b
08-04-2009   #7
Quote   Quote: Originally Posted by squonksc View Post
That's interesting since the Linksys wired G type router refuses to connect through the modem while the activity between pc, nic card, and router is solid. And that's with an ethernet connection.
The wireless usb adapter also saw activity between the three while a large red X was still present between modem and router.
 HELP 64bit modem adsl driver problem problems?
Similar Threads for: HELP 64bit modem adsl driver problem
PC PSU for ADSL modem Hardware & Devices
ADSL PCI Modem Drivers Drivers
SY602 ADSL Modem Driver Drivers
ADSL modem DSL-200 Hardware & Devices
Windows 7 RC ADSL Modem Driver Drivers
