Sound in Control Panel problem
jordan359
9:27 PM
Hello All,
I was wondering. Does any one know how to get the "Apply" button working again?
In my Windows 7 x64 on the Sound options in the Control Panel it is shaded grey all the time. So, when I'm trying to set the default sound to Bluetooth it is not possible to Apply any changes. To this end, the sound has be switched over manually every time I boot up the laptop.
Any ideas?
Windows 7 x64 Home PremiumAMD Phenom II x6 1055t 2.8GHzKingston KVR1333D3N9/4G x 2Sapphire ATI HD5450 1Gb
Good luck secondhand system 350
ASRock 785GM-S3
Realtek HD audio
AOC e2343F2
Seagate Barracuda 7200,16Mb,1 Tb
480 W
JNP C06
Cooler Master Hyper TX3
Logitech K400
Logitech K400
15 Mbps
Optical Drive : Sony Optiarc AD-5360S
That's really weird. How about restoring your pc before that problems occurs?
How about the OK button is also disabled?
Win7 Pro SP1 x64AMD K10 Athlon(tm) II P340 Dual-Core Processo...DDR3 4.0GB (3.74 Usable)AMD M880G with ATI Mobility Radeon HD 4250 25...
HP G62-340US Notebook
Win7 Pro SP1 x64
AMD K10 Athlon(tm) II P340 Dual-Core Processor ~2.2GHz
Hewlett-Packard 1444 69.37/AMD 785GX/BIOS F29
AMD M880G with ATI Mobility Radeon HD 4250 256MB Video
ATI RS785/RS880 - High Definition Audio Controller
SAMSUNG 156AT09-H04
1366x768 - 344 x 194 mm, Pixel Clock 69.30 MHz
WDC WD3200BEVT-60A23T0 320GB
Bought on July 03, 2011
Have just started System Restore only to discover that I have one point to restore to. This point is after this issue with the "Apply" button started, so that would be ineffective. The "OK" button is fine.
ASRock 785GM-S3
Realtek HD audio
AOC e2343F2
480 W
JNP C06
Logitech K400
Logitech K400
15 Mbps
Windows 7 Ultimate SP1 - 64 BitIntel Core i5 2500k2x4GB DDR3 1333HzAti Radeon 6770
Novatech iRush Pro
Intel Core i5 2500k
Foxconn H67M-S/H67M-V/H67
2x4GB DDR3 1333Hz
Ati Radeon 6770
None
Samsung S22B150
2x500GB
500W
Fan
HP KU0316
Wireless Logitech M185
20MB/s
Avast Free
Logitech M185 Mouse
KU-M316 Keyboard
I'd disable bluetooth because your sound settings may be set to "allow devices/programs to take control" of the soundchip, and in this connection it might explain the "greyed out" apply option...
Had similar problems when I left my settings like that, and when using one particular IM client, the soundchip was bound to the IM client by association, even after closing that program... which mean't I lost audio in every other respect...
W7 x64Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9...4Gb OCZ Gold 1,333MhzPalit HD4850 O/C Sonic 512Mb DDR3, Dual DViD's
Custom built machine
W7 x64
Intel Q9300 2.5Ghz Quad LGA775 (Would like Q9650)
Gigabyte GA-EP45T-UD3R (F6 Bios)
Azalia to twin Samson 50w Studio Monitors
Twin Dell (E-IPS) U2311H 23.6" Screens
1920 x 1080 @ 60Hz
Crucial M4 SSD, archives on twin Western Digital Caviar Black WD2002FAEX, 2TB, 7200rpm HDD's, Samsung Ritemaster CD/DVD Burner...
OCZ 600w
Lian-Li PC8 acoustifoamed' aluminium tower
Scythe 140mm Zipang
Cherry PS/2 custom model
Lenovo USB laser "Thinkpad" Mouse
ADSL2+ @14Mbps downstream & Cat6 Gigabit Ethernet
NOD32
Opera
Silicon Dust HD Homerun Dual FTA (Ethernet) TV Tuners, Dray Tek Vigor 2850Vn router and 8x HP Gigabit Switch. Lian-Li CR26 Card Reader, Canon MF4430 iSensys laser printer/scanner.
ASRock 785GM-S3
Realtek HD audio
AOC e2343F2
480 W
JNP C06
Logitech K400
Logitech K400
15 Mbps
Novatech iRush Pro
Intel Core i5 2500k
2x4GB DDR3 1333Hz
Ati Radeon 6770
None
Samsung S22B150
2x500GB
500W
Fan
HP KU0316
20MB/s
Avast Free
Logitech M185 Mouse
KU-M316 Keyboard
Hey,
Iv'e tried to do the sfc /scannow repair thing using the original Windows 7 installation disk supplied with my laptop. I got the reply from the command prompt window of "Resource Protection could not start the repair service"
I think that I'm looking of a re-install of the Windows system.
So, this morning I decided to do a full Windows 7 re-installation. Now, would you believe it. The same greyed out "Apply" button is still there. This is odd!
ASRock 785GM-S3
Realtek HD audio
AOC e2343F2
480 W
JNP C06
Logitech K400
Logitech K400
15 Mbps
Have now got that sfc /scannow working on my machine. It has reported that I did have some corrupt files, it has repaired them and then I rebooted. The lack of the "Apply" button is still evident.
Frustrating.
ASRock 785GM-S3
Realtek HD audio
AOC e2343F2
480 W
JNP C06
Logitech K400
Logitech K400
15 Mbps
