Intel Management Engine Interface shows ! on my control panel
  1. Posts : 146
    Windows 7 Ultimate X64 RTM
    Can anyone help me sort this out, its the first time I've seen this and it looks annoying knowing that there is a form of error on my PC even though it does not affect my usage at all, I want to either get rid of this all together or find the necessary drivers for this to be fixed.
    It also says Device cannot start under its device status, I have no clue what this thing is.
  2. Posts : 1,996
    Windows 7 Home Premium 64 bit
  3. Posts : 1,996
    You may want to right click on the device to uninstall it, then install it again using the downloaded file.
  4. Posts : 146
    Thanks!
  5. Posts : 49
    windows 7 pro 64 bit
    Earlz, did it work? It's not a driver issue, the Intel will not work with Windows 7--I have the same issue.
  6. Posts : 1,996
    Try this one.
    Install the driver from the device manager.
    http://www.station-drivers.com/downl...ivers.com).exe
