Windows 7: need help coprocessor problem
15 Dec 2012   #1
bronson99
windows 7 32bit
hi guys new to this forum but i came because im mega stuck ok here is my problem my computer is crashing with blue screen of death after about 15mins of gameplay on everything ive tried everything i know drivers up to date its had a fresh format all windows updates are done. the only thing i can see is if i open device manager i get the little yellow warning sign on coprocessoor could this be the problem and how do i fix it ? ive tried clicking update drivers but it wont work.
computer specs are
windows 7 32bit
geforce 8800gt gfx card
geforce610pm-m2 motherboard
amd athlon(tm)64 x2 600+ processor
thanks for any help
15 Dec 2012   #2
pebbly
Hi bronson99, Welcome to the forums, Redownload and reinstall the chipset drivers for your motherboard from the manufacturers website , This will solve your problem
15 Dec 2012   #3
bronson99
windows 7 32bit
ok im top noob lol can somebody please post a link to where i can get what i need i cant seem to find them
15 Dec 2012   #4
pebbly
Quote   Quote: Originally Posted by bronson99 View Post
Who made the motherboard ? or which make/model of PC do you have then I will find the drivers for you
15 Dec 2012   #5
bronson99
windows 7 32bit
thank you i think its a biostar geforce610pm-m2
15 Dec 2012   #6
bronson99
windows 7 32bit
or when i look in system info it says system manufacturer ECS
15 Dec 2012   #7
pebbly
Hi bronson99 Try these drivers ECS Web Site > GeForce6100PM-M2 (V2.0) they are the same geforce drivers as your motherboard ,download the winvista/win7 32bit chipset driver
15 Dec 2012   #8
bronson99
windows 7 32bit
oops told you i was a noob its not biostar thats in my other comp this one says ecs on the motherboard
15 Dec 2012   #9
pebbly
Thank you for that ,I searched the biostar website and could not find a matching mobo so automatically went to the ECS website
15 Dec 2012   #10
bronson99
windows 7 32bit
downloading now i will let you know how it goes thanks for your help
Coprocessor Driver PROBLEM (Code 28)
i already check some of the threads here about this kind of error i tried to figure out what i can do but i think i will need to do it in another way because their version of Win7 is different from mine as well as their computer and everything so i decided to make a special thread for my PC...
Drivers
COPROCESSOR problem
I have a mic made by logitech that has no drivers because it says it's built into the OS. I have tried downloading drivers and updating things. The thing says it could not install coprocessor. I have a dell studio 1440 (i think) please help me!
Hardware & Devices
Coprocessor driver problem
I used to have alot of problems with my laptop crashing using Vista. I bought Windows 7 and did a clean install and now I'm having problems with 7 crashing. Then I noticed the coprocessor didn't have a driver, nor can I find the right chipset driver for it. At this point I should back over this...
Drivers
coprocessor problem
my problem is coprocessor not found..anyone can help me to fix the problem..thnx..
Drivers
Hp Coprocessor problem
Hi I recently did a clean install of windows 7 home premium (64 bit) on my notebook Hp Pavallion Dv6700z CTO. It came from Hp with Vista home premium (64 bit) installed. My processor is an AMD Turion 64 x2 Mobile technology TL-60 2.0 GHz (amd lists this as a dual core). It has 2.0 Gb ram w/ 64 bit...
Drivers
HP DV6500 Coprocessor Problem (Windows 7)
I have an HP DV6500 with an AMD TL-64 processor and the NVidea GeForce 8400M GS graphics card. It's the rs085av model. I recently installed Windows 7 Pro 32 bit, and I managed to install all the drivers except for two items. It shows "Coprocessor" and "Unknown Device" as incorrectly installed....
Drivers
