Driver Problem Help !!!
i want to know how to install my old network drivers in my windows 7 for this i cannot access my net
Hi Debajayoti, Welcome to the forums , If you would be so kind and tell us the make/model of your PC we will strive to help you further :)
My PC Config.
intel pentium 4 with (HT) at 3.00ghz
ram- 1GB
Hard Disc- 80GB
Audio-onboard
Graphics-Onboard
Motherboard- Gigabyte 8i865gme-775-rh
please help me....
When i installed the network driver (Intel PRO\100 VE) IT GETS INSTALLED BUT THE NETWORK COMPONENT IS NOT DETECTED
Hi Debajyoti, Download the Vista 32 bit driver from here Network Connectivity — A guide to Intel® PRO/100 Network Adapter drivers install in compatibility mode :) Intel no longer offer suport for the pro series cards Intel® PRO/100 VE Desktop Adapter — End of interactive support announcement so a win7 driver will never be available
u are really a seven guru thank u.:):)
i want to ask is my staff really supports windows 7?
shall i go for an upgrade?
Hi Debajyoti, You're very welcome , Your PC is quite capable of running Win7 as long as it's for "everyday use" like internet surfing email etc ,it will not play the latest games or do heavy graphic work, but if you do not wish to do those things then I personally would not bother upgrading yet, If you do want to play the latest games etc then your only option is to upgrade :)
i have installed the vista drivers and its working thank you very very much
