BELKIN Wireless G USB adapter Problem- again
  1. Posts : 6
    Hi all members.
    I read alot topics on this forum to try solve my problem. I found in here 2 topics about Belkin Wireless G USB adapter , but still i have a problem
    I describe whats the problem .
    I try to instal on my Windows 7 x64 b.7000 drivers for belkin w g usb adapter f5d7050
    I download drivers 4 belkin usb adapter f5d7050 ver.3(like I read about it) - before install i change in install file the compability for all users to windows xp , but it dont wanna install(I get a error)(the product only supports Win200/Winxp32/Vista32/Vista64) , then i switch compability for windows vista and instaler go on,
    While installer is going it ask to connect adapter to usb ,what i do, but it seems dont find any anyway .
    After all when instalation is finish i just get information that device dont work proply , and the light in adapter never go on
    I try update drivers from menage device but still device is not working
    I really dont know what else i can do
    Mayby that will be some clue
    i install Windows 7 on separetly partition "E" , so I have on c: vista , and on disc e:Win7 , but in windows 7 mode i cant see partition with Windows vista(I can see just in Disc menagment, that she still there),
    . when i open windows vista i see all partitions.
    did it make any sense?
    I can make some screens if it help .
    anyway my main problem is to instal belkin drivers 4 adapter to WORK fine,
    Please help, and sory for my english but thats my second language
    Regards tasman
  2. Posts : 1,027
    Windows 7 Ultimate x64/ Windows Vista Ultimate x64
    When you did the update driver in the device manager did you browse to the belkin folder in your program folder.
    I never had to install the driver with any compatibility. I just installed it then I just updated the driver in the device manager and going into the program files/belkin/model number and then it started to work.
  3. Posts : 6
    I have program files and Program files(x86) on same partition , in Program Files(x86) i go to belkin but its no Belkin.exe file at all just sec i make a screen
  4. Posts : 6
    i cant find this file , just look i make A screen :
    http://www.freeimagehosting.net/imag...3408c65124.jpg
    by the way its imposible to find proply instal files i think ,in old ver of windows i could find easly files after instal and here i havent got clue whats going on?
    Cant see anywhere instalation files as well ??
    http://www.freeimagehosting.net/imag...10de3109de.jpg
  5. Posts : 995
    XP/win7 x86 build 7127
    as far as "seeing" your vista drive, make sure it has a drive letter assigned to it while you are in disk management... should also say healthy of course
  6. Posts : 6
    ok i sort drive, but still my network is not working
