Base System Device Problem?
i got question mark on my system device in Devise Manager...
what driver or software should i install? my laptop is dell inspiron 1420
ok here you go
Hello Kupalski,
I believe it will be the Ricoh driver download listed under the Chipset section at the Dell driver webpage below. The only problem is that Dell only has 32-bit Vista drivers available for your computer model. These will work fine in a 32-bit Windows 7, but not a 64-bit Windows 7.
Drivers & Downloads
I did find these 64-bit Vista drivers for the Ricoh R5C833 that may work for you though.
Drivers and Downloads
Thanks to this forum i could install all my Inspiron 1420 drivers.
I share the link with all drivers (Hosted by me).
http://www.ignaciofigueroa.com/drive...io/R171786.exe
http://www.ignaciofigueroa.com/drive...oh/R166188.EXE
http://www.ignaciofigueroa.com/drive...ad/R192617.exe
Good luck!
i have try changed settings SATA both achi and ata, both also cannot continue the installing win7 64bit step.
the problem i meet is b4 go into the select drive to install,
it ask me load driver, it required CD/DVD drive device driver is missing.
how do u solve this?
@jacky45 the easiest way to install windows Seven if your having cd/dvd driver missing problems is to create a Windows Seven USB drive ISO and install it form their. USB Windows 7 Installation Key Drive - Create Here is also a long thread with the same problem and a lot of different solutions or suggestions. CD/DVD Driver missing on install Fabe
