Windows 7: Solve a problem with your power management system - Leovo Laptop
05 Sep 2014   #1
DorianDiaconu
So, before installing the driver that was recently uploaded on the Lenovo support site, I didn't have this error.
(I own a IdeaPad Z50-70)
I got the correct version for my Windows. I'm using Windows 7 on 64 bits.
05 Sep 2014   #2
maxie
windows 7 home 64bit
About six months ago had a friend that got a new Lenovo ... There was an Intel app update for it from Lenovo Website ..
Upon Installing it crashed his Computer ...
Had to do a Restore ...
So maybe you should go back to the old Version ..
06 Sep 2014   #3
DorianDiaconu
Quote   Quote: Originally Posted by maxie View Post
There was no Engery Managemet driver for my laptop until now...
06 Sep 2014   #4
maxie
I am surprised your System did not come with it Installed ...
Have you Uninstalled it ? ....
07 Sep 2014   #5
DorianDiaconu
It was a Free-DOS laptop.
No, I didn't.
07 Sep 2014   #6
maxie
It is very likely the reason this Driver gives you an error .. Is because it requires other Drivers to be Installed in order for it function properly ....
If you really want it to work i am sure that is possible .. ?
It is not really required as Windows has that Function already ...
I can't turn on laptop! Power button problem
Sorry for reposting thread. I hope this doesn't ruin my reputation as a person. My other thread was named incorrectly, therefore not getting as much notice. Sorry about that. :huh: Anways.... Okay, this is I did something really dumb. Yesterday I was changing the thermal paste in my laptop for...
General Discussion
Upgraded laptop hard drive, disk management unallocated space problem
I upgrade my laptop hard drive to 1tb hitachi travelstar and restoring the image with macrium reflect went well and prompted to reboot. After rebooting, it showed the hp logo then a black screen with an underscore on the top left, no hard drive activity. Windows boot manager said "the boot...
General Discussion
Laptop mousepad & power problem?
One of my friend HP laptop 6910p has mouse-pad problem. The mouse pad works fine while laptop is consuming battery but when charger is plugged-in, the mouse pad get stuck. Original Charger output is 90W. When another charger of 65 watt was connected then everything was working fine. Voltage output...
Hardware & Devices
Will System Sweeper also solve this problem?
Here the suggestion is to boot to a system repair disc or the equivalent thereof via system restore and run: bootrec.exe /fixmbr Don That solution is easy, but can I get rid of the pest by running System Sweeper? Will MSE or MSRT be updated to get rid of this guy?
System Security
BSOD: Power Management System Failure
Is Windows 7 . . . - x86 (32-bit) or x64 ? x64 - the original installed OS on the system? NO - an OEM or full retail version? Promotional Upgrade - equivalent to Full Retail - OEM = came pre-installed on system - Full Retail = you purchased it from retailer - What is the age of system...
BSOD Help and Support
Dell M1710 Laptop - System Freezes Applying External Power
So, if my system is working fine on the power supply and I disconnect it to run on battery, this works fine... but when I plug the laptop back in, the system locks up. Any ideas?
Hardware & Devices
