Windows 7: AMDA00 interface driver problem causing further problems
31 May 2015   #1
canemichael97
windows 7 64 bit
I have a custom build pc with a asus z97 motherboard. On boot i would get error messages saying driver failed to start. After closing these windows explorer would fail to work and programs would not open, also after these dialogue boxes are closed the sound does not work also. After booting into safe mode and opening device manager i can see that listed under system devices is the AMDA00 interface driver with the yellow exclamation mark. I have no AMD components in my PC. Is this what is causing my issues?
Any help/ideas is greatly appreciated
Many thanks, Mike
31 May 2015   #2
GokAy
Read https://social.technet.microsoft.com...8itprohardware
Short: Disable it in device manager until it has been fixed.
01 Jun 2015   #3
Boozad
Do you have ASUS AI Suite installed? It's part of that, namely ASUS Probe (I think).
01 Jun 2015   #4
canemichael97
windows 7 64 bit
I do not have it installed it came with my card but i never installed it as i have no use for it
01 Jun 2015   #5
Boozad
What card? It's the motherboard utility.
01 Jun 2015   #6
canemichael97
windows 7 64 bit
oh no i have a asus gtx 770, my board is a asus z97k but i dont not have that software installed, sorry i got confused on my last post the software came with my board but was never installed
01 Jun 2015   #7
Boozad
It's definitely something to do with the motherboard, it's possible Windows could have installed a defective driver for it through Windows Updates. Can you open Device Manager and expand System Devices and see if you have any signs showing.
01 Jun 2015   #8
canemichael97
windows 7 64 bit
Only on that one driver i have disabled it and trying to see if it is working better now, haven't had any problems yet
01 Jun 2015   #9
AddRAM
Windows 7 Pro x64 Windows 10 Pro x64
It`s not an AMD component, it just happens to use those letters. Actually it`s AMDA
I have it, with no issues.
I don`t have any Asus software installed either, but I did use the disc for drivers.
I guess it`s just there in case you ever use the sensor probes. But I see no reason to.
Asus Z87-Pro AMDA00 Interface driver...
AMDA00 Interface Problem - Graphics Cards - Graphics Cards
AMDA00 Interface, Win7x64, Win8x64, Win7x32, Win8x32
01 Jun 2015   #10
canemichael97
windows 7 64 bit
must have just been installed with the drivers then, i will leave it disabled for a while to see if that solves the problem
teredo tunneling pseudo interface missing driver or not available
For all those people out there who are missing this interface on there Windows 7 computer there is a solution, but you might not like the way it needs to be fixed. "What is teredo tunneling pseudo interface?", this interface is built in the operating system as well as the drivers for this...
Drivers
Sound Device / Driver Problems Causing BSOD
I have no clue - I have no sound, reinstall the driver, get a BSOD, reboot using Last Config that worked which gives me back my sound until I attempt to logoff, which hangs because Windows can't play the logoff tune. It eventually shuts down, but on reboot I have no sound. Repeat cycle.
BSOD Help and Support
Driver causing computer to freeze...which driver? Windows 7 64bit
Hello, I have a Sony Vaio that just recently started freezing after startup for no apparent reason. I initially thought the freeze maybe caused by the HDD so I purchased and installed a SSD (the computer needed updating anyway.) Along with the SSD, I put a fresh install of Windows 7 on...
Drivers
Audio interface causing CPU to cycle up and down
Hi, I'm new to the forums so I hope this in the right place. I recently bought a new laptop, an ACER 5742 i5 with 4GB ram and 500GB HD with Windows 7 64 bit Home premium. I've had a number of problems already, initially a problem with the in built soundcard drivers but that was resolved by...
How do I find out what driver is causing the problem?
I got stop code 0x000000C5. Googling this, I found how to run driver verifier. MS was confusing, so I went to this web site: Using Driver Verifier however, I am getting the impression that driver verifier is supposed to CAUSE a BSOD if there is a problem. I know I need to run driver...
ASUS D2/PM Driver causing itunes problem
all the features work fine in itunes but as soon as I install my Asus D2 drivers itunes won't start unless it's in compatibility mode and then some of the features (like drag and drop) don't work, why would the drivers be causing problems with itunes? :confused:
