Need Embedded Intel Sound Card Help
  1. Posts : 3
    Win 7 Ultimate
    Hi --
    Forgive me if this post is redundant, I searched this forum before I posted...
    I am performing a clean install to Win 7 Ultimate on an older Dell Precision 530. Running into the usual driver errors and have one that I can't locate...
    I need a Win 7-compatible driver for a Intel(r) 82801BA/BAM AC'97 Audio Controller. It is a sound card that is embedded into the motherboard. I have searched for days but cannot locate a driver that works. The few I found said they work but do not...
    Any help would be greatly appreciated!!! :) Thanks in advance.
    Ryan
  2. Posts : 3,960
    W7 x64
    Try installing the drivers you found in Vista or XP compatability mode.
    It's very possible there is no specific W7 driver if your Dell machine is getting just a little long in the tooth
  3. Posts : 3
    Win 7 Ultimate
    I'm not sure what you mean... I can't even see the sound card when Win 7 loads...
  4. aem
    Windows 7 Ultimate 64Bit
    Go to the Intel site and download it. :)
  5. Posts : 3
    Win 7 Ultimate
    Gee I hadn't thought of that
