Windows 7: Need Embedded Intel Sound Card Help
07 Dec 2009   #1
Win 7 Ultimate
Hi --
Forgive me if this post is redundant, I searched this forum before I posted...
I am performing a clean install to Win 7 Ultimate on an older Dell Precision 530. Running into the usual driver errors and have one that I can't locate...
I need a Win 7-compatible driver for a Intel(r) 82801BA/BAM AC'97 Audio Controller. It is a sound card that is embedded into the motherboard. I have searched for days but cannot locate a driver that works. The few I found said they work but do not...
Any help would be greatly appreciated!!! Thanks in advance.
Ryan
07 Dec 2009   #2
W7 x64
3rd Rock from the Sun
Try installing the drivers you found in Vista or XP compatability mode.
It's very possible there is no specific Windows 7 driver if your Dell machine is getting just a little long in the tooth
07 Dec 2009   #3
Win 7 Ultimate
I'm not sure what you mean... I can't even see the sound card when Win 7 loads...
Quote   Quote: Originally Posted by Qdos View Post
07 Dec 2009   #4
aem
Windows 7 Ultimate 64Bit
Go to the Intel site and download it.
07 Dec 2009   #5
Win 7 Ultimate
Gee I hadn't thought of that
Quote   Quote: Originally Posted by aem View Post
 Need Embedded Intel Sound Card Help problems?
Similar help and support threads for: Need Embedded Intel Sound Card Help
What ext video card takes SPDIF audio from ext sound card? Graphic Cards
BSODs playing GTA IV - No Sound (Sound Card) & Laggy Video! BSOD Help and Support
Solved S/PDIF Optical out - No sound from receiver (onboard and sound card) Sound & Audio
Creative Sound Blaster Audigy 24bit Sound Card Drivers
FPS drop because of sound card / sound card drivers? Gaming
