Problem with sound card driver
  1. Posts : 6
    windows
    Well i have a 5.1 PCI surround cart SL-8866-SRD and we i install the driver it says "Can't find your device. Please plug in your device and press Retry to continue" what should i do?
    PS:I have connected the sound card, that's why i am confused.
  2. Posts : 6
    windows
    nobody replies
  3. Posts : 8,383
    Try getting the driver from windows update :)
    Get the driver here: http://www.speed-link.com/?p=2&cat=17&pid=21068&paus=2
  4. Posts : 6
    windows
    Get the driver here: SPEEDLINK / Products / PC Accessories / Sound Cards / Stage 5.1 PCI Soundcard
    Ok the driver works perfect but i have another problem now, all of my speakers work in the Test(sub and the 5 speakers) but when i am listening to music only 2 speakers and the sub work!
    Can you help me?
  5. Posts : 8,383
    Can you help me?
    Go to Start>Control Panel>Hardware and Sound>Sound
    Select your speaker then click configure
    Select 5.1 then click Next and Finish
  6. Posts : 6,879
    Win 7 Ultimate x64
    Then things are working as they should. Unless the source is encoded in 5.1, without using some kind of upmix (speaker fill, X-Ear 3D as it is called on C-Media based cards, CMSS3D on Creative cards, etc) is used all you will get is stereo.
  7. Posts : 3
    Wimdows 7 Ultimate
    ayuda, yo solía tener Win XP, pero puse el Ultimate 7 Win, y ahora por 3 meses de no coger el sound.and tratar muchos conductores y nada Help me estoy desesperado
