Windows 7: plz help me out with AUDIO problem
28 Apr 2009   #11
srs audio soundmix
i will check it out . thanks
Search this Thread:
Advanced Search
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
"Scan for Hardware Changes" fixes audio problem, but problem returns
Hi all, Issue: The sound on my internal laptop speakers does not work when I try to play audio. Solution: However, if I go into "Device Manager" and click "Scan for Hardware Changes" on the "Sounds, video and game controllers" section, my sound returns instantly. The moment I click "Scan..."...
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio problem
Hello all, my audio was working fine for a year, but a few days ago there was no sound, so I restarted my computer and the sound worked for 30 mins or so then went out. I checked to see my drivers were up to date and they were. So then I uninstalled the driver and tried to reinstall one from HP...
