Windows 7 Forums Search
Windows 7 - plz help me out with AUDIO problem
04-27-2009   #1
win7
i have lenovo 3000 N100 with win 7 beta installed on it.(build 7070 ultimate.
previous xp was removed completly as i had a lot of problem with some .dll file.
controller info. microsoft 6.1.70770 saying this device is working fine .
YET i have no audio sound at all , video working fine.
i got realtek driver file and installed yet no sound !
any idea what i am doing wrong ?
thanks for any help
04-27-2009   #2
Windows 7 Professional 64-bit
Have you checked lenovo's website for any drivers?
04-27-2009   #3
win7
Quote   Quote: Originally Posted by swarfega View Post
yes i have but no luck . i left some message their too on lenovo forum.
04-27-2009   #4
Windows 7 Ulti. x64
Hello, wkgbn Welcome to SevenForums
Most of the time with a new install if something do not work then its a driver issue. But you should also have a look at volume controls. I know you have done that already so you say you where running xp and then installed seven. Maybe you need to use the xp drivers? Have you ran windows update to see if windows can help find drives for your sound device. Maybe un-install your device from device manager and let windows recognize it again. good luck and hope you enjoy seven.
04-27-2009   #5
It looks like you have a SoundMax audio controller, you might want to try this driver from Toshiba, it's always worked perfectly for me.
I posted a thread about SoundMax earlier, it looks like the default Windows 7 drivers, even in RC are buggy.
download
04-27-2009   #6
win7
[quote=myzr7;79968]Hello, wkgbn Welcome to SevenForums
Thanks for the welcome....
ammmmmmm like you said i checked volume control & what have you many time.
xp drivers wo'nt work. i already updated driver 2-3 time and finally
like you said i un-installed the driver and let the window select the best one YET no luck.
i am not giving up till i find the solution :PPP
04-27-2009   #7
Have you tried the driver package from my earlier post?
I've used the same driver for each build of Windows 7 and it works perfectly.
I Googled your laptop and we share the same audio controller, namely 'SoundMax'.
Damn thing that it is.
04-27-2009   #8
04-27-2009   #9
win7
[quote=Dazeon;80011]Have you tried the driver package from my earlier post?
hi ! Dazeon . man o man you are the man .
soon as i downloaded- installed the driver you said ; BINGO . it's working fine. you saved my day ( go gurdy go - )
many thanks to all you guys. Daz-Myzy7-Swarfega.
04-27-2009   #10
Good stuff mate, glad I could help.
You might want to hang on to that driver for RC, whilst my audio worked straight off with build 7100, it was extremely quiet until I installed that driver.
If you find that your audio isn't quite as loud as you'd like, then I would recommend you grab a copy of 'SRS Audio Sandbox', it really seems to bring out the best from the SoundMax controller. Certainly makes mine louder and sharper.
http://www.srslabs.com/store/store/c...sp?idProduct=6
Unfortunately though it isn't free.
Happy listening!
 plz help me out with AUDIO problem problems?
Similar Threads for: plz help me out with AUDIO problem
Audio problem Sound & Audio
Audio Problem With latest Audio Driver 2.41 Sound & Audio
audio problem Sound & Audio
Audio Problem Sound & Audio
