Windows 7 - Realtek ethernet and wireless CARD problem |
05-01-2010
#1 | | |
Realtek ethernet and wireless CARD problem I have some problems with these two Realtek card, before installing windows 7 all was ok (using XP) :
Problems:
1) Some downloads from particolar site do not start and remain in waiting, for example I can not donwload from HTML.it web site. I think that it depends by download protocol used by site but I am not a expertise. Others sites are OK like microsoft.com and all download are available and work ok.
2) Virtual LAN inside Virtuabox does not work, and in the virtual machine guest (XP ) internet connection it is impossible.
3) Some applications fails automatic update
I have buyed a new Realtek wireless card but above problem are same.
Note that on my XP partition on the same PC all work ok.
Please, help me!!
Thank you to all
Andrea | My System Specs | | System Manufacturer/Model Number HP a6442.it OS windows 7 64bit CPU Inter Core 2 Quad Motherboard asus Memory 4GB Graphics Card NVIDIA geoforce 81600 Monitor(s) Displays HP 22" |
05-01-2010
#2 | | Windows 7 Ultimate 64-bit |
Quote: Originally Posted by andreap I have some problems with these two Realtek card, before installing windows 7 all was ok (using XP) :
Problems:
Please, help me!!
Thank you to all
Andrea My dearest Andrea,
I want to make sure I am understanding all of this correctly:
- Both your ethernet connection and wireless connection suffer from the problems you described?
- Are you connected to a router at any time?
- Do you have any firewall software and if so what is it? | My System Specs | | OS Windows 7 Ultimate 64-bit CPU AMD Phenom II X6 1090T 3.2GHZ Motherboard MSI 890FXA-GD70 Memory G.SKILL RipJaw 3x2GB DDR3-1066 Graphics Card 2x HIS Radeon HD 6850 1 GB Sound Card VIA 8-channel Monitor(s) Displays 2x 20 inch Acer LCDs, 1x 32" Sony LCD TV Screen Resolution 4480x900 Keyboard Microsoft Wireless Keyboard 1000 Mouse Microsoft Wiresless Mouse 5000 PSU Kingwin 1000W Modular Case Coolermaster HAF 932 Cooling 1x 120mm, 3x 200mm, CoolerMaster Hyper 212+ Hard Drives 1x Crucial 64GB SSD
3x 1TB HDDs (WD, Seagate, Hitatchi)
1x 500GB Seagate External Internet Speed 20mbps Other Info Samsung BD-ROM/DVD-RW |
05-02-2010
#3 | | |
Dear jelyman,
thank you very much for your answer and sorry for my english  .
Yes!
- Are you connected to a router at any time? Yes, my router is an ADSL Alice (Telecom Italia) with two connection type: cable and wireless
- Do you have any firewall software and if so what is it? No, I have only Windows 7 Firewall
I hope that you can help me, I like Windows 7 but I could decide to downgrade my system if this problem is not solvable.
Have you a nice day
05-02-2010
#4 | | Windows 7 Ultimate 64-bit |
Ok I have more questions.
Are your router and ADSL modem the same unit or do you have two independent units?
What is the make and model of the wireless card you currently have installed in your system?
[ps: i'd reply in italiano but I'd have to use software and it may not come out right] | My System Specs | | OS Windows 7 Ultimate 64-bit CPU AMD Phenom II X6 1090T 3.2GHZ Motherboard MSI 890FXA-GD70 Memory G.SKILL RipJaw 3x2GB DDR3-1066 Graphics Card 2x HIS Radeon HD 6850 1 GB Sound Card VIA 8-channel Monitor(s) Displays 2x 20 inch Acer LCDs, 1x 32" Sony LCD TV Screen Resolution 4480x900 Keyboard Microsoft Wireless Keyboard 1000 Mouse Microsoft Wiresless Mouse 5000 PSU Kingwin 1000W Modular Case Coolermaster HAF 932 Cooling 1x 120mm, 3x 200mm, CoolerMaster Hyper 212+ Hard Drives 1x Crucial 64GB SSD
05-03-2010
#5 | | |
Hi jelyman,
My answers in red color:
Are your router and ADSL modem the same unit or do you have two independent units? Yes, the router and ADSL modem are the same unit.
What is the make and model of the wireless card you currently have installed in your system? WIRELESS Manufacturer: Techmade, link to model: Adattatore PCI LAN Wireless 802.11g 54M Installed driver for chipset: Realtek 8185 Extensible 802.11b/g Wireless Device ETHERNET
Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) Others info
Browsers IExplorer 8 and Firefox have the same behavior
Ciao
05-03-2010
#6 | | |
Hi jelyman,
I think that problem is not the LAN and wireless card, but Windows 7, Please, could you verify this link: "http://download.html.it/software/getit/4636/avira-antivir-personal-free-antivirus/", what protocol type is it used to download this file?
From others site I can download without problem, others no (like above link) my be that sites with problems have different download protocol, is it possible??
Andrea
P.S. Ti prego aiutami a risolvere il problema! | My System Specs | | System Manufacturer/Model Number HP a6442.it OS windows 7 64bit CPU Inter Core 2 Quad Motherboard asus Memory 4GB Graphics Card NVIDIA geoforce 81600 Monitor(s) Displays HP 22" |
05-03-2010
#7 | | Windows 7 Ultimate 64-bit |
Are your router and ADSL modem the same unit or do you have two independent units? Yes, the router and ADSL modem are the same unit. One thing I would try is to get a hold of your ADSL provider and ask them to do a line check. Although this is happening with 7 and nothing else, it never hurts.
Also, have you power-cycled the modem recently? [unplug from power source, wait 30 seconds, plug in]
Do you have any friends that have a Windows 7 machine they can bring to your location? I ask this because if they do, hook up your ADSL to their machine. If they experience the same problem it's likely your modem and we can go from there. Quote: What is the make and model of the wireless card you currently have installed in your system? WIRELESS Manufacturer: Techmade, link to model: Adattatore PCI LAN Wireless 802.11g 54M Installed driver for chipset: Realtek 8185 Extensible 802.11b/g Wireless Device Do two things for me on this one:
1. Check your XP installation to see if that same "Realtek 8185" driver is installed.
2. After visiting the Techmade site [and translating it to english] I found a link for the drivers provided by the manufacturer. Try installing those drivers instead. Of course if you can create a restore point just in case something goes wrong and the world explodes [figuratively].
Download Link: http://www.tech-made.com/driver/TM-WP61R.zip Quote: ETHERNET
Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) Give your Ethernet drivers an update. A new version was released on April 21st, 2010.
This link should work: ftp://WebUser:K4d5wHY@202.134.71.21/...8_04202010.zip
If not, head here: http://www.realtek.com/downloads/dow...&GetDown=false
and choose: Windows 7 32/64 Auto Installation Program (SID:1400998)
From others site I can download without problem, others no (like above link) my be that sites with problems have different download protocol, is it possible?? I am able to download the file just fine. It comes to you via HTTP just like the web site's content does. Quote: P.S. Ti prego aiutami a risolvere il problema!  Farņ il meglio che posso per aiutarvi, signorina! | My System Specs | | OS Windows 7 Ultimate 64-bit CPU AMD Phenom II X6 1090T 3.2GHZ Motherboard MSI 890FXA-GD70 Memory G.SKILL RipJaw 3x2GB DDR3-1066 Graphics Card 2x HIS Radeon HD 6850 1 GB Sound Card VIA 8-channel Monitor(s) Displays 2x 20 inch Acer LCDs, 1x 32" Sony LCD TV Screen Resolution 4480x900 Keyboard Microsoft Wireless Keyboard 1000 Mouse Microsoft Wiresless Mouse 5000 PSU Kingwin 1000W Modular Case Coolermaster HAF 932 Cooling 1x 120mm, 3x 200mm, CoolerMaster Hyper 212+ Hard Drives 1x Crucial 64GB SSD
1x 500GB Seagate External Internet Speed 20mbps Other Info Samsung BD-ROM/DVD-RW Realtek ethernet and wireless CARD problem problems? All times are GMT -5. The time now is 05:49 PM. |  |
