Sony ericsson w700i pc suite problem
hello all, i have a se w700i mobile and i used to connect it to my pc via usa cable when i was on xp and it used to work fine but for some reason am not able to install se pc suite for w700i on windows 7.. whenever i run the installer i get the error failed to load resource. when i checked on microsoft site about this problem, its mentioned that, that pc suite isnt compatible so i tried running it in xp and vista compatibility mode but still kept getting the same failed to load resource problem. does anybody know how to get my w700i synced with my pc? and by am using 64 bit win 7. thanks
