Need For Speed: High Stakes Problem
Collin
4:20 PM
i have installed this before and it worked, now all of a sudden i get an error message showing this...
Any Ideas? and i already ran it in compatibility mode for 95, 98 and XP to no avail.
Windows 72.3hz3GB
2.3hz
3GB
SAMSUNG
1280x1024
250GB
Compaq
Compaq
Try running in admin, 256 colours, 600X800, etc.
~Lordbob
Windows 7 Ultimate x64, Mint 9Intel i5-2500k2x 4Gb Corsair VENGEANCE DDR3-1600NVidia GeForce N260GTX Twin Frozr
Hera
Intel i5-2500k
ASUS P8P67 Pro
Realtek HD OnBoard Audio
ASUS 24" Monitor
Cooler Master Haf 932
Fans
Razer Tarantula
Razer Lachesis
not fast enough
Windows 72.3hz3GB
2.3hz
3GB
SAMSUNG
1280x1024
250GB
Compaq
Compaq
Edit: Need time to reevaluate, I'll then reply.
HP Win7 Pro x64 | Custom Win7 Pro x64HP PhII X4 965 Black Ed. 3.4Ghz | PhII X6 110...8GB DDR3 1333 OC Black Edition x2HP XFX Radeon HD4890 1GB | AMD Radeon HD 6990
HPE-112y Custom + Custom Build
HP PhII X4 965 Black Ed. 3.4Ghz | PhII X6 1100T 3.3/3.7
OEM HP | ASUS Crosshair IV Extreme 890FX
Realtek 7.1 Digital HDMI x2
HP 20" 1680x1050 LCD | Samsung 23" 2ms 1920x1200 LED
1680x1050 + 1920x1200 & HDTV for Gaming/TV
1TB WD "Green" 5,400 RPM SCSI W/ AMD RAID/Xpert
Custom 2x 128GB OCZ Enyo SSD
Thermaltake Black Widow 850watt Modular x2
HP HPE- 112y OEM Modded | Custom Xclio A380S
HP Antec120mm | Custom Antec 360mm/250mm/200mm/120mm
HP G15 | G19
G500 x2
15mb down, 2mb up
2x DVD-RAM | 2x BD-ROM
i installed it before on this exact os!!!! and now it refuses to even install? what is that all about :(
Windows 72.3hz3GB
2.3hz
3GB
SAMSUNG
1280x1024
250GB
Compaq
Compaq
When I installed this game from the CD-Rom, I put the setup.exe on Windows 98 Comp, and that's it. It worked for me just fine.
Windows 7 Ultimate 32-BitIntel(R) Core(TM) i7 CPU 920 @ 2.67GHzCorsair DDR3 4GbNvidia Ge-Force GTS250
Gigabyte Technology Co., Ltd. EX58-UD3R
Corsair DDR3 4Gb
High Definition Audio Device
Envision 19 inch
1280x1024
2 physical hard drives (4 letter drives) that equal up to 626.3 gigs of space all together. I think both are Maxtors, but primary is a SATA drive, secondary is a SATA, too.
"Elite" style case
"Cooler Master"
Microsoft Optical USB Mouse.
Verizon DSL Internet
Got same problem here as Collin.
I have even tried putting .sdb patches using Application Compatibility Administrator.
Still nothing.
I think the compatibility setting is getting applied only to setup.exe and not the files it extracts in the %temp% folder.
Found a lengthy procedure over at RC1 & Need For Speed: High Stakes! - Neowin Forums
Though the instructions are for the Demo, I don't see why they won't work for the Retail version.
Currently the only way seems to get the installed files from a PC which has it already installed and also its registry settings, and then import them into Windows 7.
P.S:
I remember installing a certain update from Windows Update:
Update for Windows 7 (KB976264)
Installation date: ‎08-‎05-‎2010 12:17 AM
Installation status: Successful
Update type: Recommended
Install this update to resolve issues with non-compatible applications for Windows 7. For complete details of this update, see Knowledge Base Article KB976264. After you install this item, you may have to restart your computer.
More information:
http://support.microsoft.com/KB/976264
Help and Support:
Can this be causing any issues?
The list of apps does not include any NFS games though.
Richardc269, can you please confirm if you have this update installed?
Thanks!
Windows 7 Ultimate (64 bit) dual boot with Fe...Intel Corei5-3470 @ 3.20Ghz (Turbo 3.60Ghz) [...8 GB [4 GB x 2] DDR3 1600 Mhz G.SkillZotac nVidia GeForce GTX 650 1024 MB GDDR5 (1...
Custom built
Windows 7 Ultimate (64 bit) dual boot with Fedora KDE
Intel Corei5-3470 @ 3.20Ghz (Turbo 3.60Ghz) [6MB L3 cache]
GIGABYTE GA-B75M-D3H [intel B75 Express Chipset]
Zotac nVidia GeForce GTX 650 1024 MB GDDR5 (128 bit)
Realtek ALC 887 HD Audio codec onboard
Samsung SyncMaster 2033SW+
1600 x 900 @ 60Hz
1 x S-ATA II Seagate 1 TB [Win7 Ultimate x86-64 RTM]
1 x S-ATA Samsung 1 TB [Fedora]
Cooler Master Thunder 650W
Cooler Master Elite 344 - USB 3
All Fan [1 on front and 1 at back]
Microsoft PS/2 Multimedia keyboard
Microsoft Optical Mouse USB
1 Mbps Cable
Kaspersky Internet Security
that is an ass load of work, why cant it just install >.>
Windows 72.3hz3GB
2.3hz
3GB
SAMSUNG
1280x1024
250GB
Compaq
Compaq
i hope this isn't a bump D:, i just want to play this game again so bad. im not saying wtf why is no one posting, im just curious as to why it wont work now >.>
Windows 72.3hz3GB
2.3hz
3GB
SAMSUNG
1280x1024
250GB
Compaq
Compaq
The reasons are obvious.
1) This game was made in 1999.
2) Things have moved on and when they do, they leave old ways for newer and better ways.
3) There's ONE and ONLY ONE way to get this game to work:
a) Install this game and it's latest patch (4.50 I believe) on any Windows below Vista OR get it from a place which has it already installed ALONG-WITH its registry settings.
b) Import the registry settings in Windows 7 and play by using PATCHNFS.exe instead of NFSHS.EXE.
The only thing which won't work is Videos. Its sad but it can't be helped.
I think that's about it. Neither you nor me can do anything about it as we are not the ones that make either Windows or the game.
I hope I don't sound rude. If I do, then I am sorry, but things have to be made clear.
Cheers! and have a good time playing Need for Speed High Stakes!
P.S: Please don't blindly import the registry settings as you have to specify the path where NFS is in your system. Right click the registry file and click on edit and change any necessary settings.
Custom built
1600 x 900 @ 60Hz
1 Mbps Cable
what about installing the game in an xp install in virtualbox and playing it that way?
Windows 7 Ultimate x641.80 GHz Intel Core 2 Duo processor T71003 gig ddr2NVIDIA GeForce 8400M GS
HP dv6519tx
3 gig ddr2
15.4” WXGA High Definition BrightView Widescreen
1280 x 800
Hitachi 320 GB (5400 rpm)
90 W AC Power Adapter
Kitchen plate under the lappy
101 key compatible
Touch Pad with On/Off button and dedicated vertical Scroll
Three Wireless internet prepaid using E160G USB dongle
window's 7core 2 quad2gb corsairati hd4850
window's 7
core 2 quad
gigabyte
2gb corsair
ati hd4850
lg
1600 X 900
power logic
none of the spec above is accurate
