I need help for a weird problem.
Learn2
11:23 AM
Hey guys, real sorry in advance if this has been all explained in another thread :$
Here's what happened :
I went from Vista to 7 home premium without any trouble and installed my usual programs. Then my computer started crashing with some IRQL less or equal BSOD errors while I was downloading files (>3mbps). The problem persisted (but had no effect at all on speed during startup) and I grew a bit tired of it so I chose to follow the system's advice to troubleshoot the startup. Since then, my computer started taking over 15 minutes to boot and even though I scrolled countless threads, I managed to fail resolving the problem. Then I though that I maybe had messed up something in the OS so I reinstalled, making sure that I had formatted everything. The problem is that the startup is stil WAY slower than what it used to be : from a startup time of 45s before the troubleshoot (when i went from vista to 7) to around 4minutes. I tried starting with minimal settings and it still takes over 2 minutes...
Just in case it can give an insight to anyone, the startup lags at the "windows starting (with the pulsing flag) and then right after I put my PW in to log.
ESET's system inspector tells me that my drivers are fine and my windows index is still the same at 4.6. Windows troubleshoots detect no problem whatsoever.
All in all, I just don't get what's wrong with my lappy, so I'm asking for help !
Thanks all in advance
Learn2
MS Windows 7 Home Premium 64-bitIntel Mobile Core 2 Duo T5750 @ 2.00GHz4.0GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)512MB GeForce 9500M GS (Acer Incorporated [ALI])
Acer Aspire 6920g
Acer Aspire 6920 (U2E1)
Generic PnP Monitor @ 1366x768
313GB Western Digital WDC WD3200BEVT-22ZCT0 (IDE)
optical drive : MATSHITA BD-CMB UJ-120 ATA Device
Windows 10, Home Clean InstallIntel Core2 processsor Q8200(2.33Ghz 1333FSB)...6 gbATI Radeon 256MB HD3650
Dell XPS 420
6 gb
Intergrated 7.1 Channel Audio
Dell SP2009W 20"
640 GB Serial ATA Hard drive
Fan
Dell USB Keyboard
Dell Premium Optical USB
DSL 2.85
Welcome to Sevenforums,
You might want to have a look at your Mfg Computer Site, looking for proper drivers side by side with the one windows 7 installed. Could be a bios update to do also, from the Vista one to Windows 7 one..
Asus P8Z77-V LE PLUS
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
500Go Sata 6Gb/s (x2)
500Go Sata 3Gb/s (x2)
SSD 60Go Sata 6Gb/s
Thermaltake Chaser A71
Custom Water Cooling Loop
Cooler Master QuickFire XTi
Razer Imperator 2012 (4G)
IE 11.0.xxx Rtm
Learn2
On the slim chance do you have a backup from before the problem that we can restore from? do you have a working win 7 dvd to do a repair install?
ken
HP Pavillion dv-7 1005 Tx
Win 8 Release candidate 8400
[email protected]
4 gigs
Nvidia 9600M
HD built-in
17" Wxga
none
45Mb down 5Mb up
Learn2
Welcome to SevenForums.
do a System Restore from a point BEFORE the problem appeared.
WIN + F1 | type System Restore | Enter key
WIN is that key with wavy flag on it.
MS Windows 7 Ultimate SP1 64-bitAMD A10-4600M6.00 GB Dual-Channel DDR3 @ 798MHz (11-11-12-28)AMD Radeon HD 7660G
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
"WIN + F1" huh? :huh:
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
WIN + F1 brings up Help and Support on my machine.
Windows 7 Ultimate 32 bitIntel(R) Pentium(R) 4 CPU 3.00GHz2.50 GB RAMNVIDIA GeForce 7600 GS
Home built
ASUS P4P800-VM Motherboard Chipset: Intel 865G + ICH5
2.50 GB RAM
SoundMax Integrated Digital Audio (Chip)
ViewSonic VX 1962 wm
1680 X 1050
Seagate Barracuda 7200.10 80 GB
ST380215A ATA Device 18.6 GB
Western Digital "My Book" external hard drive 750 GB
Fan based
Microsoft Comfort Curve Keyboard 2000 v10 USB
Logitec optic USB
3.01 Mb/s download 0.64 Mb/s upload
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
I did try to do a restore to a version prior to the bug, and it worked (the restore), but the startup speed still was crappy... I already did the winkey + f1 and there's nothing i could find there.
I'm making sure sure that all my drivers are up to date and I'll read those links you guys gave
thanks so much for the lightning fast answers
Acer Aspire 6920g
Learn2,
would you do us a favor please and fill in your system specs.
Following is very helpful.
SPECCY- System Information Tool
http://www.piriform.com/speccy
Operating System, CPU and Temp, Ram, Motherboard, Graphics, Hard Drives, Optical Drives, Audio, Peripherals, Network info.
Simply put—this is the best and it’s free!
This info helps us to give you a reasonable answer.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
:D It's a done did thing like they say in teh deep south
Acer Aspire 6920g
I don't know how to instal a BIOS update and don't want to mess it up, could I get advice on that ? I did download the BIOS update from ACER, but I'd like more info on how to get it done!
Thanks again
L2
edit : SOZ 4 doubleposting.
edit : I went straight to the ACER site to dl the latest drivers and it didn't fix the problem. (added +-5seconds to bootup)
Acer Aspire 6920g
Acer no doubt provides explicit instructions on doing a bios update for your particular model.
Here's another idea or a couple:
1. WIN | type disk cleanup | enter key
Be sure to also check the advanced tab but don't let MS delete programs which you seldom use.
2. Download, install, run CCleaner
3. WIN | type msconfig | Enter key | startup tab
Uncheck everything except that which is from Microsoft or Acer or Synaptics. Now Restart your computer. Only re-enable something if you have problems.
Let us know if your system is now running faster.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
Those 3 steps have already been done without any real benefit!
edit : that's what acer tells on the website : "Updating an incorrect BIOS may cause harm to your system. We recomend that you only do this after being instructed by one of our Customer Care representatives. By using these updates you agree to accept the possibility of product failure."
scary
Acer Aspire 6920g
"Updating an incorrect BIOS may cause harm to your system".
That's completely correct, I almost never suggest someone "mess with" the BIOS as the system can/will be ruined forever if done incorrectly.
* BFK Customs *
W 7 64-bit Ultimate
ASUS P5Q Pro
ATI : XFX 5870
Corsair 620HX
Microsoft 500
14 Mb/s
so what do I do?
edit : K so I'm now looking at the 1.16 BIOS update... How can I know if it's for 64bit or 32bit ?
I just run Winphlash and make sure that the .ROM is V1.16 ?
Acer Aspire 6920g
so what do I do?
The bios is for every computers 6920G running any OS...Acer is quite easy on Bios update (i do own one!), run the WinPhlash and that's it. It might reboot aswell. It had sometimes fixed some troubleshootings to update the bios when an upgrade had been made from Vista to Windows 7.
Do you remember which one App/driver had caused the + 5seconds on boot?
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
SSD 60Go Sata 6Gb/s
IE 11.0.xxx Rtm
I'm reading something on the 1.16 bios update in this site :
Acer 6920G Bios Updated 1.16v released
and it looks like I need to use a bootable USB flashdrive ??
Looks hella complicated
Es-tu certain qu'il faille seulement cliquer sur le .exe comme ça ?
(are you sure that I only have to click on the .exe?)
edit : I'm more concerned about the 3minute extra than the few seconds my new programs delay during startup :P
Acer Aspire 6920g
As an experiment ... disable Eset (in services) and reboot. Is it the same slow boot up?
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
