I need help for a weird problem.
Page 2 of 6 FirstFirst 1234 ... LastLast
  1. Posts : 10,200
    Learn2,
    would you do us a favor please and fill in your system specs.
    Following is very helpful.
    SPECCY- System Information Tool
    http://www.piriform.com/speccy
    Operating System, CPU and Temp, Ram, Motherboard, Graphics, Hard Drives, Optical Drives, Audio, Peripherals, Network info.
    Simply put—this is the best and it’s free!
    This info helps us to give you a reasonable answer.
  2. Posts : 19
    MS Windows 7 Home Premium 64-bit
       #12
    It's a done did thing like they say in teh deep south
  3. Posts : 19
    NoN said:
    Welcome to Sevenforums,
    You might want to have a look at your Mfg Computer Site, looking for proper drivers side by side with the one windows 7 installed. Could be a bios update to do also, from the Vista one to Windows 7 one..
    I don't know how to instal a BIOS update and don't want to mess it up, could I get advice on that ? I did download the BIOS update from ACER, but I'd like more info on how to get it done!
    Thanks again
    L2
    edit : SOZ 4 doubleposting.
    edit : I went straight to the ACER site to dl the latest drivers and it didn't fix the problem. (added +-5seconds to bootup)
  4. Posts : 10,200
       #14
    Acer no doubt provides explicit instructions on doing a bios update for your particular model.
    Here's another idea or a couple:
    1. WIN | type disk cleanup | enter key
    Be sure to also check the advanced tab but don't let MS delete programs which you seldom use.
    2. Download, install, run CCleaner
    3. WIN | type msconfig | Enter key | startup tab
    Uncheck everything except that which is from Microsoft or Acer or Synaptics. Now Restart your computer. Only re-enable something if you have problems.
    Let us know if your system is now running faster.
  5. Posts : 19
       #15
    Those 3 steps have already been done without any real benefit!
    edit : that's what acer tells on the website : "Updating an incorrect BIOS may cause harm to your system. We recomend that you only do this after being instructed by one of our Customer Care representatives. By using these updates you agree to accept the possibility of product failure."
    scary
  6. Posts : 22,814
    W 7 64-bit Ultimate
       #16
    "Updating an incorrect BIOS may cause harm to your system".
    That's completely correct, I almost never suggest someone "mess with" the BIOS as the system can/will be ruined forever if done incorrectly.
  7. Posts : 19
       #17
    so what do I do?
    edit : K so I'm now looking at the 1.16 BIOS update... How can I know if it's for 64bit or 32bit ?
    I just run Winphlash and make sure that the .ROM is V1.16 ?
  8. NoN
       #18
    Learn2 said:
    so what do I do?
    The bios is for every computers 6920G running any OS...Acer is quite easy on Bios update (i do own one!), run the WinPhlash and that's it. It might reboot aswell. It had sometimes fixed some troubleshootings to update the bios when an upgrade had been made from Vista to Windows 7.
    Do you remember which one App/driver had caused the + 5seconds on boot?
  9. Posts : 19
       #19
    I'm reading something on the 1.16 bios update in this site :
    Acer 6920G Bios Updated 1.16v released
    and it looks like I need to use a bootable USB flashdrive ??
    Looks hella complicated
    Es-tu certain qu'il faille seulement cliquer sur le .exe comme ça ?
    (are you sure that I only have to click on the .exe?)
    edit : I'm more concerned about the 3minute extra than the few seconds my new programs delay during startup :P
  10. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
       #20
    As an experiment ... disable Eset (in services) and reboot. Is it the same slow boot up?
