I need help for a weird problem.
Page 4 of 6 FirstFirst ... 23456 LastLast
  1. Posts : 19
    MS Windows 7 Home Premium 64-bit
       #31
    here are the p/s
    Attached Thumbnails Attached Thumbnails I need help for a weird problem.-ps1-log-.png   I need help for a weird problem.-ps2-log-.png
  2. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
       #32
    Very strange, mine is 2.03 mb
    Under Options make sure the following options are select[*]Verify Code Signatures[*]Hide Signed Microsoft Entries
    Click File > Refresh
    Click File > Save As
    Save it to the desktop as autoruns.txt
    Post the contents of autoruns.txt as a reply to this topic
  3. Posts : 19
       #33
    here's the autorun
    thanks alot for the help!
    I need help for a weird problem. Attached Files
  4. Posts : 8,608
       #34
    Sorry I didn't give you the full instructions ... I thought I did, but I guess my post got lost
    Double click on autoruns.exe to start Autoruns. Wait for it to finish scanning
    Under Options make sure the following options are slected
  5. Posts : 8,608
       #35
    LOL! Now where did the echo come from
  6. Posts : 8,608
       #36
    *File not found: rdpclip*
    What did you download in that 300 MB's that might have contained a virus or malware?
    http://www.learnxpress.com/fix-rdpcl...xe-easily.html
  7. Posts : 19
       #37
    rdpclip is a service that I disabled using the blackcobra site someone posted on here, so it shouldn't be of any problem.
    I purrrty much tried everything
  8. Posts : 8,608
       #38
    This is showing too "File not found: C:\Users\Learn2\AppData\Local\Temp\esihdrv.sys"
    http://www.greatis.com/appdata/d/e/esihdrv.sys.htmIs
    Did you pay for Eset or download it from a crack? Your computer is trying to find what it can't find ... no wonder the boot time is so slow
  9. Posts : 19
       #39
    I don't have a crack for Eset, I didn't even think it was possible!
    What is the file my comp is looking for ? The boot was slow even before I installed Eset
  10. Posts : 8,608
       #40
    First download TFC by Old Timer TFC - Temp File Cleaner by OldTimer - Geeks to Go! and save it to your desktop.
    Save any unsaved work. TFC will close ALL open programs including your browser!
    Double-click on TFC.exe to run it. If you are using Vista/Windows 7 right-click on the file and choose Run As Administrator.
    Click the Start button to begin the cleaning process and let it run uninterrupted to completion.
    Important! If TFC prompts you to reboot, please do so immediately. If not prompted, manually reboot the machine anyway to ensure a complete clean.
    TFC (Temp File Cleaner) will clear out all temp folders for all user accounts (temp, IE temp, java, FF, Opera, Chrome, Safari), including Administrator, All Users, LocalService, NetworkService, and any other accounts in the user folder. It also cleans out the %systemroot%\temp folder and checks for .tmp files in the %systemdrive% root folder, %systemroot%, and the system32 folder (both 32bit and 64bit on 64bit OSs).
    It shows the amount removed for each location found (in bytes) and the total removed (in MB). Before running, it will stop Explorer and all other running apps. When finished, if a reboot is required the user must reboot to finish clearing any in-use temp files.
    NOTE***TFC only cleans temp folders. TFC will not clean URL history, prefetch, or cookies. Depending on how often someone cleans their temp folders, their system hardware, and how many accounts are present, it can take anywhere from a few seconds to a minute or more.
    TFC will completely clear all temp files where other temp file cleaners may fail. TFC requires a reboot immediately after running. Be sure to save any unsaved work before running TFC
    Next,
    Download Malwarebytes' Anti-Malware to your desktop
    |MG| Malwarebytes Anti-Malware 1.46 Download
    * Double-click mbam-setup.exe and follow the prompts to install the program.
    * At the end, be sure a checkmark is placed next to Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish.
    * If an update is found, it will download and install the latest version.
    * Once the program has loaded, select Perform full scan, then click Scan.
    * When the scan is complete, click OK, then Show Results to view the results.
    * Be sure that everything is checked, and click Remove Selected.
    * When completed, a log will open in Notepad. Please save it to a convenient location. Copy and Paste that log into your next reply.
