Window 7 Build 6956 Problem.Need help.
  1. Posts : 14
    Window 7 Build 6956
    Hello guyz..im new here..i have problem with my HDD in Win 7.
    Which is while in Win Vista i have C:\ and D:\ directory.But after i format to
    Win 7 the D:\ is gone.i only have C:\.can someone fix this?..its kin of hide or something..please help me..rely appreciate it.
  2. Posts : 155
    Windows 7 Build 7100 32-bit, Windows Vista 32-bit
    I have the same thing:
    C: = Windows Vista
    D: = Personal stuff, downloads, etc.
    G: = Windows 7
    When in Vista, I see all those drives. In Windows 7 however, I don't see the C: drive with Vista. Instead, the G: drive becomes the C: drive.
    I couldn't really be bothered though, and I don't know a fix for it either...
  3. Posts : 22,814
    W 7 64-bit Ultimate
    Hello dota, welcome to Se7en Forums!
    That's common, nothing to be worried about; though I don't have the expertise to explain it satisfactorily for you. Keep checking back; someone that can explain it will be along soon.
    Later Ted
  4. Posts : 14
    Window 7 Build 6956
    hi Kid :)..
    ya hethoofd..me too..my D:\ change to my DVD Drive..sob
    anyone pro here...
  5. Posts : 1,402
    Hi there
    Put your windows cd in your drive and reboot, and then do a start up repair. That should sort it.
  6. Posts : 14
    Window 7 Build 6956
    are u sure?..i have do clean format of win7 2x becoz of this problem..but still my D:\ dir is missing..
  7. Posts : 1,524
    Hi dota,
    From 7
    Start, right click on computer, Manage, Disc Management.
    You should see your drive all you have to do is to assign it a drive letter
    by right click.
    It probably happens to stop accidental erasure or your Vista drive and seems to be normal. I have even gone so far as to hide my 7, C:\ drive while I am in Vista so that all my other partitions have the same drive letters when viewed from both OS's
    I hope this helps
    Pooch
  8. Posts : 1,402
    Thanks Pooch!
  9. Posts : 14
    Window 7 Build 6956
    pooch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    so!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    much!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    i get it back!!!!!!!!!!!!!!!!!!!!!!!1111111 :)
    thanks so much pooch,u a truely an expert dude!!
    ~~~PROBLEM FIXED~~~ :)
  10. Posts : 22,814
    W 7 64-bit Ultimate
    Hello dota.
    See, I told you someone would be along to help.
    Thanks Pooch and Echrada!
    Later Ted
