Windows 7: Help help help !!!
25 Oct 2010   #1
Mihajlo
Windows 7 Ultimate 32bit
Help help help !!!
1. problem : Hi , I am installed Windows 7 Ultimate 32bit on 512mb ram and 2.4 processor (i like playing with computers) and graphic card 64mb (i don't know full name xD ) ,
I am log on and the screen resolution was 640x480 , i have an old monitor , 1024x768 , i first go on right click , screen resolution and i can't change the resolution ...
: Imageshack - newbitmapimageak.jpg - Uploaded by Imageshack user
2. problem : I can't install the Windows 7 Themes , i think it's because i havent Theme Patcher , i don't know , im begginer with this OS ...
25 Oct 2010   #2
yowanvista
A graphic card with 64MB and 512MB of RAM are below the requirements for Windows7
You won't be able to use any Aero themes
Windows 7 System Requirements Upgrade PC Video Graphics Media
Most probably you have not installed your graphics drivers (which won't ever support Win7 as your 64MB card is too old)
25 Oct 2010   #3
Orbital Shark
Hi Mihajlo, welcome to the forums
Your first issue is that Windows has detected your card as Standard VGA Adapter which is why you cannot change past 640x480. Your best option at this moment is to find out the exact make & model of your card and download the relevant drivers for it.
Note   Note
You may find that the latest drivers will be for Vista so try installing them in Compatibility Mode for Windows 7
I have had Windows 7 installed on a rig with only a 64MB card and did indeed manage to get the Aero themes working but it did behave very sluggish.
25 Oct 2010   #4
Orbital Shark
Another thing to note is the version of DirectX that your card can handle natively e.g. what the hardware was written for. You'll find that if your card does not fully support DX 9 or above then you wont be able to have the Aero look.
25 Oct 2010   #5
karlsnooks
Quote   Quote: Originally Posted by Mihajlo View Post
Welcome to SevenForums.
I congratulate you on getting Win 7 to run on your computer. If you can get some more ram, then 1 GB and preferably two GB will bring a big performance improvement.
 Help help help !!!
