An old fart needs help to keep up with grandson.
Page 1 of 3 123 LastLast
  1. DG8
    windows 7 ultimate 32 bit
    I am far from being computer savy but I need help to get my grandchild off my back.
    He as a big fan of games and I hate them, but he has been complaining that the games are very jumpy and he has asked me to get a bigger memory? Known very little about this form of computing I'm not sure whither he means a larger graphic card - more memory or both?
    If I attache a Beleric Advisor could someone tell me the best way to upgade the computer which will enable my grandson and myself to be happy whit our own projects
    ** Removed file since it contained your key numbers **
  2. Posts : 4,663
    Windows 7 Home Premium 64 bit
    We're quite a majority of old farts on here so a very warm welcome to the forum
    Most members post their system specs in their user cp (see at top of the page) then they display in My System Specs (bottom right in the post box)
    Can't say I've ever seen a Belarc Advisor before. Quite complicated. Seems you have plenty of hard drive space for some games and you have 2gb of RAM memory, am I right?
    Can't see a graphics card in there. Have I missed it?
    Your Grandson probably means both more RAM and a graphics card (or a better one).
    The card would be the priority I'd have thought although 4gb of RAM rather than 2 would also speed up the frame rate in games.
    Cheers, John.
  3. Posts : 12,012
    You have "only" 2 GB of RAM. Windows might be a little snappier on 4 gigs and your motherboard will certainly accommodate another 2 GB---you have 2 empty RAM slots.
    But improving the video card would likely make a more noticeable improvement in gaming performance. It's a Dell Inspiron 530. Looking at the Belarc report, it appears to have graphics integrated on the motherboard, rather than a separate card.
    You need someone to confirm that the Dell in fact has integrated graphics and that it has a spare slot that can accept a separate video card. Then shop for a compatible video card. I'd try that first and if your grandson is still unhappy, try upgrading the RAM to 4 GB total.
    If money is no particular concern, do both at the same time.
  4. Posts : 352
    Windows Home Premium 64bit
    Hi DG8. Please check your private messages now.
    Regards
    JohnnyA
    Edit: Disregard, someone beat me to it. RE: Belarc
  5. Posts : 4,663
    Ah. I see one of the moderators have removed it as it contained your serial number. Don't worry, it was only there a minute and I never noticed it amongst everything else.
  6. Posts : 12,012
    I just downloaded a user manual for a Dell Inspiron 530.
    It says you have Intel integrated video, as suspected.
    And it says you have 4 slots:
    2 PCI
    1 PCI Express x1
    1 PCI Express x16
    So, it certainly appears you can upgrade to a separate video card easily. Anything compatible should be an improvement, even at the $50 range. Intel integrated video wasn't too good 3 years ago when your PC was designed.
  7. Posts : 222
    Win 7 Ult + Starter, XP Pro +Home, 2kAS, Linux Mint 8, SuperOS
    The Dell specs for this PC is here:
    Dell Inspiron 530 Desktop PC Product Details | Dell UK
    Assuming 32-bit Windows 7, the maximum addressable ram is 3GB, the further 1GB in an upgrade will only be utilized if the Windows 7 OS is upgraded to 64-Bit. (this may mean that some installed software and hardware may not work properly)
    From the current Core 2 Duo installed, the processor could be maximally upgraded to a Intel® CoreTM 2 Quad-Core Q9450 Processor (2.66GHz, 12MB cache, 1333MHz FSB), and there are possibly even faster compatible processors, I didn't look further.
    The Graphics card upgrade has been mentioned in another post above.
  8. Posts : 128
    Windows 8 X64 M3 8102 / Windows 7 Ultimate X64
    I Agree more ram and a mid range GPU will make the PC fly!!
    a good bang for buck GPU i use on the pcs i havd built for friends i have eather put one of these cards in it
    Radeon 5770
    Radeon 6850
    Radeon 6870
    Radeon 6970
    Geforce GT440
    Geforce GTS450
    Geforce GTX570
    Geforce GTX560Ti
    Ranging from $150 - $500 MID to High end cards
    Extreme cards are around $ 700 - $1000
    For an Idea
    Geforce GTX580
    Geforce GTX590
    Radeon 6990
    Radeon 5870
    i have a 3rd pc for gaming when friend come over basicly same specs
    Q6600 with a G41 with 16x PCIe and 1x PCIe so i got a radeon 6870 for video and a Physics card a Geforce 9600GT PCIe 1x 512MB
  9. DG8
    May I thank everyone who replied to my problems. I will need to keep the replies and take my time to try to digest the information provided (I'm a slow learner)
    I appreciate the effort you have put in to try and help me.
    Blessings to you all.
  10. Posts : 12,012
    According to Crucial.com's highly reliable configurator, a Dell Inspiron 530 has these RAM requirements:
    4 GB maximum overall
    1 GB maximum per slot (you have 4 slots)
    Each memory slot can hold a 240-pin DIMM of DDR2 PC2-5300 (aka DDR2-667) or DDR2 PC2-6400 (aka DDR2-800) non-ECC RAM, preferably rated at 1.8 volts.
    Dual channel is supported--this means you should think in terms of buying 2 more sticks rather than 1--presumably 2 sticks of 1 gig each, giving you a total of 4 GB of RAM overall.
    1 GB sticks sell for about $20 in the USA.
