Windows 7: USB Problem. Need HELP BADLY.
05 Apr 2011   #31
Windows 8.1 pro
Quote   Quote: Originally Posted by gregrocker View Post
I wish you would have let Kingston tech support help you figure out the issues - they're very engaged with what their memory is doing or not doing.
Try the manufacturer tech support for the brand you have now. It may even be a known issue but unseen here by someone who knows the issue.
You should be able to clean all and reformat the stick that was unsafely removed: Clean and Clean All with Diskpart Command - Windows 7 Forums
the sticks thas was unsafely remove was unable to detect on any system I plug it into, it is totally busted thanks for all the help!
10 Apr 2011   #32
Windows 8.1 pro
hi there, it's been a time since i posted here. I just get a refund on my USB stick purchased. I bring a laptop together with my files in their shop and test almost all of their 1GB sticks, and ohh.. well.. none of them works.. except for the 4GB, 8GB sticks ^_^ even their 2GB fails. thanks for all the help.
10 Apr 2011   #33
Thanks for posting back to let us know about this issue with 1gb USB flash sticks.
Search this Thread:
Advanced Search
need help badly
I am pulling my hair out. It started out cause My system HP Compaq 2010 win 7 64 bit, Stopped seeing or recognizing my Fuji Camera. Somebody said get a card reader, so I got this $6.00 one from big lots. Should be OK I thought. Still would not recognize card reader. So I don't know, maybe the...
General Discussion
Badly upgraded
Hey I've recently purchased an upgrade CD from xp to windows 7 after making sure I had all the criteria right. I followed the steps to the letter but when I tried exctracting the old files I got an error message saying "This version of update\update.exe in not compatible with the version of...
Installation & Setup
Need help really badly
Ok again i need help. Short verison of the story, some files are missing off my computer idk how many i only know of 2 and those are under My computer under S3A8955D004 click the User folder and there is usually 3 folders the one missing is default, now the other folder you Click on the one that...
General Discussion
New Help Badly... BSOD
I have followed the BSOD - Posting Instructions and need some help finding out why my system keeps crashing. Please help I am running windows 7 home premium
BSOD Help and Support
Need your help so badly.
I previously have a dsl connection provided by pldt before and thats the time that i used windows 7 and activated it online. after few months ive changed my internet provider to smartbro wireless internet but when i reformatted my pc and reinstalled my windows 7 again and tried to activate it...
General Discussion
Just installed '7' and need help badly!
Hi all! I just installed win7 home 32. I have 2 important questions. 1 - On my DVD/s letters J and K respectivly, when I have a disc in them The letters change from DVD RW Drive J to DVD RW Drive (J:) Win_7 Compatible Then in the Computer Management, under the drives, it says: ...
General Discussion
