Hi there,
Sorry for this, I don't know if I'm the right section but please let me.
I have bought a new Flash drive (1GB) to use as storage for my driver installers and application.
When I copy my files it seems to be alright and finished without any problem. I safely remove the USB from the Computer and shut down my system.
When I'm about to use it to one of my friend's PC and error came out. "Please insert Last Disk/Multi Volume Set...blah blah.." I click ok, but error pops-out again so I click cancel.
All of my files on the USB drive don't work or corrupted, folders are empty, some of the installers work, but with only size amounting from 1kb-800kb. I also tried using the warranty and replacing it with a new one but still same problem, I also tried copying these files to other computer and try if it will do the trick but no luck.
I also tried formatting my USB drive several times but no luck, even tried the low-level format as what stated to other forums but no luck. I don't know how to fix this, if I'm about to use the warranty again and same problem, I have to dump this USB disk.
So I really need your help. Thanks!
Windows 8.1 proAMD Athlon II x3 440 3.0Ghz4GB 800Mhz DDR2 Dual ChannelNvidia 9600GT 512MB 256bit
- Computer type
- PC/Desktop
- Custom Build
- Windows 8.1 pro
- AMD Athlon II x3 440 3.0Ghz
- Motherboard
- Asus M4A78
- 4GB 800Mhz DDR2 Dual Channel
- Graphics Card(s)
- Nvidia 9600GT 512MB 256bit
- Sound Card
- Built-in Realtek HD Audio
- Monitor(s) Displays
- HP 17" widescreen monitor.
- Screen Resolution
- 1400x900
- Hard Drives
- 500GB Wesstern Digital Caviar Blue SATA
320GB Seagate 7200rpm IDE
- PSU
- Gigabyte 550p 450W
- Case
- Emaxx Rebel Casing.
- Cooling
- DeepCool Iceberge Mini-FS
- Keyboard
- Genius PS2 keyboard
- Mouse
- A4-tech
- Internet Speed
- 3mbps
- Antivirus
- ESET Antivirus 7
- Browser
- Mozilla Firefox
