Solved USB Problem. Need HELP BADLY.
Add your apps one by one until you find the one corrupting stick.
actually, I tried putting some pictures/videos on the stick, the pictures were broken and some pixels are misplaced or gone, videos are corrupted and unable to play. when I reconnect the stick, Pictures are gone videos are corrupted.
I'm out of options, I'm thinking now, does all USB sticks they are selling in that shop is this kind?
Windows 8.1 proAMD Athlon II x3 440 3.0Ghz4GB 800Mhz DDR2 Dual ChannelNvidia 9600GT 512MB 256bit
Windows 8.1 pro
Asus M4A78
Built-in Realtek HD Audio
HP 17" widescreen monitor.
1400x900
500GB Wesstern Digital Caviar Blue SATA
320GB Seagate 7200rpm IDE
Gigabyte 550p 450W
Emaxx Rebel Casing.
DeepCool Iceberge Mini-FS
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
the picture that I'm saying is like this, I'm thinking that the stick is damaged, but HD Surface Scan and HD tune Pro don't detect any errors. http://www.fileden.com/files/2007/9/29/1467705/picture%20pixel.png
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
Did you check the file system using Partition Wizard or Disk Check?
yes, I do that several times and passed the test, I'm now running several test using the HD Tune Pro. and it seems that It passes all the test I throw into it.
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
Try another brand of USB stick. I recommend Kingston as their RAM is second to none and tech support is fantastic.
I forgot to mention, my first USB stick I purchased from them was KINGSTON Data Traveler, when I replaced it, I choose Transcend that let me to add additional fee because transcend is more expensive than KINGSTON. both are 1GB.
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
Then I doubt it's the stick. It is something about the formatting or the way the files are loaded.
I'm now thinking I better bought those cheap sticks selling here on a less 25% of branded price, one of my unbranded sticks serves me for about a year now from the 1st purchased, it just got busted when I accidentally unplugged it from the system and causes the failure. (PC won't detect the stick.)
Well I guess this tread can now be closed, unsolved ^_^
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
I wish you would have let Kingston tech support help you figure out the issues - they're very engaged with what their memory is doing or not doing.
Try the manufacturer tech support for the brand you have now. It may even be a known issue but unseen here by someone who knows the issue.
You should be able to clean all and reformat the stick that was unsafely removed: Clean and Clean All with Diskpart Command - Windows 7 Forums
the sticks thas was unsafely remove was unable to detect on any system I plug it into, it is totally busted :) thanks for all the help!
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
hi there, it's been a time since i posted here. I just get a refund on my USB stick purchased. I bring a laptop together with my files in their shop and test almost all of their 1GB sticks, and ohh.. well.. none of them works.. except for the 4GB, 8GB sticks ^_^ even their 2GB fails. thanks for all the help.
Windows 8.1 pro
Asus M4A78
1400x900
Gigabyte 550p 450W
Emaxx Rebel Casing.
Genius PS2 keyboard
A4-tech
3mbps
ESET Antivirus 7
Mozilla Firefox
Thanks for posting back to let us know about this issue with 1gb USB flash sticks.
