- Local time
- 6:03 PM
- Messages
- 50,634
Add your apps one by one until you find the one corrupting stick.
actually, I tried putting some pictures/videos on the stick, the pictures were broken and some pixels are misplaced or gone, videos are corrupted and unable to play. when I reconnect the stick, Pictures are gone videos are corrupted.
I'm out of options, I'm thinking now, does all USB sticks they are selling in that shop is this kind?
Did you check the file system using Partition Wizard or Disk Check?
Try another brand of USB stick. I recommend Kingston as their RAM is second to none and tech support is fantastic.
Then I doubt it's the stick. It is something about the formatting or the way the files are loaded.
I wish you would have let Kingston tech support help you figure out the issues - they're very engaged with what their memory is doing or not doing.
Try the manufacturer tech support for the brand you have now. It may even be a known issue but unseen here by someone who knows the issue.
You should be able to clean all and reformat the stick that was unsafely removed: Clean and Clean All with Diskpart Command - Windows 7 Forums
