Printer Problem - or Spooler Problem
  1. Posts : 5,795
    I have a user with a Windows 7 Pro SP1 x86 laptop, and an HP Color LaserJet 1600 connected locally by USB. HP doesn't offer drivers for this printer, so we've tried the built-in ones, and the updated ones from Windows Update.
    The problem is, regardless of what is printing, the job sits in the queue, with a status of "printing". If I eventually try to delete the job, it takes several restarts before it is actually cleared out. We've swapped USB cables, reinstalled the printer twice, restarted the spooler service....no luck. The printer itself says it is ready. There are no errors, and nothing in the event logs.
    Any suggestions...or has anyone come across this issue with this or a similar printer?
  2. Posts : 18,404
    My GF's Dads HP LasetJet 4P with a laptop or a desktop running on Win 7 Home Premium x86 acts in the same way. Everything seems to be in order, sometimes will print, sometimes will just sit there like you describe. It's stumped me as there doesn't seem to be any problem.
  3. Posts : 3,487
    I had some problems with Win 7 x64 and my HP Photosmart printer. I wound up trying the Vista drivers and they worked alright. There has since been a Win 7 driver made for it, and everything now works except for the scanner. It still scans, but I can't control it from the PC, and it won't write the scanned file to an HD.
    Maybe the Vista drivers will work for you DF. I hope so.
  4. Posts : 18,404
    Are these the drivers you're using?
    Microsoft Update Catalog
  5. Posts : 1,800
    Windows 7 Pro x64 SP1
    I had a client with a HP and printer problems very similar to yours. I went to the HP site and they had a spooler fixer program that I ran and it worked fine. For some reason the print spooler gets confused.
    give it a shot.
    Rich
  6. Posts : 24,479
    Windows 7 Ultimate X64 SP1
    I have an old HP Photosmart 7960 which act the same way at times, usually after a period of non-use. When a print job gets hung, I pull the power plug for a bit and then plug it back and it prints. I have no fix for it, just use pull-plug-reinsert plug method.
    Sometimes pulling the USB cable works too.
  7. Posts : 5,795
    Yes, those are it. I'll look for the spooler fix program that richnrockville suggested, too.
  8. Posts : 18,404
    If you find it, can you post it up? I'd like to have a go at it. Can't seem to find such a program.
  9. Posts : 5,795
  10. Posts : 18,404
    Thanks. Doesn't seem to even work with the Laserjet 4P in particular. Works and has it on the list, but say it can't even connect to it on the first step. Oh well.
