Windows 7: Printer Problem - or Spooler Problem
06 Jun 2011   #1
DeaconFrost
I have a user with a Windows 7 Pro SP1 x86 laptop, and an HP Color LaserJet 1600 connected locally by USB. HP doesn't offer drivers for this printer, so we've tried the built-in ones, and the updated ones from Windows Update.
The problem is, regardless of what is printing, the job sits in the queue, with a status of "printing". If I eventually try to delete the job, it takes several restarts before it is actually cleared out. We've swapped USB cables, reinstalled the printer twice, restarted the spooler service....no luck. The printer itself says it is ready. There are no errors, and nothing in the event logs.
Any suggestions...or has anyone come across this issue with this or a similar printer?
06 Jun 2011   #2
Airbot
My GF's Dads HP LasetJet 4P with a laptop or a desktop running on Win 7 Home Premium x86 acts in the same way. Everything seems to be in order, sometimes will print, sometimes will just sit there like you describe. It's stumped me as there doesn't seem to be any problem.
06 Jun 2011   #3
Mellon Head
I had some problems with Win 7 x64 and my HP Photosmart printer. I wound up trying the Vista drivers and they worked alright. There has since been a Win 7 driver made for it, and everything now works except for the scanner. It still scans, but I can't control it from the PC, and it won't write the scanned file to an HD.
Maybe the Vista drivers will work for you DF. I hope so.
06 Jun 2011   #4
Airbot
Are these the drivers you're using?
Microsoft Update Catalog
06 Jun 2011   #5
richnrockville
Windows 7 Pro x64 SP1
I had a client with a HP and printer problems very similar to yours. I went to the HP site and they had a spooler fixer program that I ran and it worked fine. For some reason the print spooler gets confused.
give it a shot.
Rich
06 Jun 2011   #6
Britton30
Microsoft MVP
Windows 7 Ultimate X64 SP1
I have an old HP Photosmart 7960 which act the same way at times, usually after a period of non-use. When a print job gets hung, I pull the power plug for a bit and then plug it back and it prints. I have no fix for it, just use pull-plug-reinsert plug method.
Sometimes pulling the USB cable works too.
06 Jun 2011   #7
DeaconFrost
Quote   Quote: Originally Posted by Airbot View Post
Yes, those are it. I'll look for the spooler fix program that richnrockville suggested, too.
06 Jun 2011   #8
Airbot
If you find it, can you post it up? I'd like to have a go at it. Can't seem to find such a program.
06 Jun 2011   #9
DeaconFrost
06 Jun 2011   #10
Airbot
Thanks. Doesn't seem to even work with the Laserjet 4P in particular. Works and has it on the list, but say it can't even connect to it on the first step. Oh well.
Printer problem needs guru. Looks like Windows not Brother problem.
Windows 7 Professional Haven't had the need to use my printer in a couple of weeks, so I don't know when the problem started. It is a Brother HL-2270DW that has been problem free. There are tests that can be tried using the printer itself and it says it has a good connection and should be...
General Discussion
USB Printer Problem - spooler empties but no print
I have a USB printer on my Windows 7 Pro 64 bit desk top. It has worked fine for almost three years. Last the first two print jobs after boot up printed fine. The third, fourth etc. hung up in the queue which I manually emptied. Today the queue no longer stalls - rather it appears to empty...
Hardware & Devices
Printer spooler keeps stopping and printer drivers keep disappearing
I use Windows 7 Professional 64 bit. My problem is: Whenever I try to print something (word, pdf, or any other file); printer spooler stops working and when I check the “Devices and Printers” all the printer drivers seem to be disappeared. I checked the “Print Spooler” in the “Services” tool;...
Drivers
Printer Spooler Stops During New Printer Set Up
I recent purchased a a new computer with Windows 7 Home Premium x64 and a Canon MG5220 Inkjet All-in-One printer. I have setup printer to be wireless (no problems). When I run the setup disk to start downloading the drivers, etc. I get the message that the Print Spooler Service stopped and to...
Hardware & Devices
Cant Add printer as printer spooler not working
I recently bought a new desktop with Windows 7 as the OS. Have a HP Laserjet 1018 and installed it. Worked fine for a couple of days and all of sudden I get this message when adding the printer (windows can't open add printer. The local print spooler service is not running please restart the...
Hardware & Devices
PRINTER SPOOLER ISSUE! Please help me!
Well after spending about 20 hours of my life on researching this problem online and trying all kinds of "fixes" I am turing to this board for help. I have a Gateway FX 6802 - 64 bit computer running Windows 7. Brand new - purchased 2 months ago. I also have an Epson 1280 printer which I have...
Hardware & Devices
