Windows 7: Help, help help!
13 Jun 2011   #1
Josh Gellis
Windows 7 32-bit
Help, help help!
I used a free cleaner, glarysoft, I deleted some critical system folders by using it. How can I get the folders back?
The computer is running clunky because of my mistake.
13 Jun 2011   #2
richc46
Welcome
First dont use software to do the job that the computer owner can easily do.
Go back with system restore.
System Restore
When your computer is up and running, get rid of the software that is doing what you should be doing.
To maintain your computer
10 Tips on How to Properly Maintain Your Computer
Steps that I did not notice on the guide include:
Running a scan disc before doing a defrag
Using Microsoft Security Essentials and Malwarebytes.
Making System Restore points, at least once a week
Makaing a system Image once a month (varies by user)
Not relying on your A/V common sense, should prevail. You know of many sites can cause a problem.
Do not use any reg cleaning or optimizing software.
Download and use Ccleaner about once every two months. Untick any registry entries.
http://www.piriform.com/
If you follow these instructions, you will be trouble free for a long time to come.
Be sure to back up your hard drive about once a month (varies by user) and to keeep system restore points up to date.
Optimize Windows 7
13 Jun 2011   #3
Josh Gellis
Windows 7 32-bit
Uncheck registry boxes? I've always used those options, whoops.
13 Jun 2011   #4
richc46
Seven does not need registry cleaners. Most in the know in this Forum agree do not use registry cleaners. I do expect one expert, however, to come on later and tell you that its safe, never had a problem and so on. That does not change the fact that its not needed.
May I respectfully request. Read my maintenance guide slowly and digest it, piece by piece. Ask any questions as needed. I and other members will be here for you.
13 Jun 2011   #5
Hopalong X
How to fix it. Click here. Repair Install
 Help, help help!
