Logical drive does not give the option to extend volume
  1. Posts : 65
    windows7 sp1 home premium 64bit
    I don't get the option to extend my logical partition for some reason im trying to create a fifth partition so i took some GBs from my c partition which is unallocated spaced and want to add it to my logical drive to make another partition but the extend volume option is greyout im confused how can i do this?
    Thansk for any help in advanced
  2. Posts : 22,814
    W 7 64-bit Ultimate
    Hello .
    You can use the Partition Wizard boot CD to Move/Resize the left side of the Extended into the unallocated space, this snip below will give you an idea of the process and be sure to post back with any further questions you may have and to keep us informed.
    As good and reliable a program as Partition Wizard is, I would not trust the installed version for the operation you need, use the boot CD as suggested and be sure to post back with any further questions you may have and to keep us informed.
    click to enlarge
    First download the Partition Wizard Bootable Disk (PWBD) ISO file to the desktop, be sure to get the PWBD and not the installed version; scroll down to see the download link for the Bootable CD ISO file at this link below.
    Then use ImgBurn to burn the ISO to a CD, at no greater than 4x speed with a verify; it was designed for use and works best from a CD rather than a DVD; then boot the created CD to make the changes, it doesn't take any input from the user to setup, just relax and let it load.
  3. Posts : 65
    Hi bare foot kid
    i went ahead and just backed up my files tha i had in my logical drive and then deleted it .Once i did tha it automatically turn in to one with the other unallocated spaced and then i made two partitions from tha one thanks for your suggestion though im about to do a fresh install on my other machine and i might tried your suggestion just to see if it works .
  4. Posts : 22,814
    W 7 64-bit Ultimate
    Hello again.
    At least you have a solution, have a look at Method One of this tutorial for some additional options.
  5. Posts : 1
    Windows 8.1 x64
    Just wanted to say I did a Google search for how to extend a logical partition and Bare Foot Kid's answer and links were still totally valid and worked perfectly for me today. thanks so much. Only difference was that I put the ISO on a USB and made it a bootable Linux usb device.
  6. Posts : 22,814
    W 7 64-bit Ultimate
    Hello tommyriley, welcome to Seven Forums, glad I could be a help!
