need help in Partitioning hard drive using disk management
  1. Posts : 2
    Windows 7 home premium 64 bit
    i bought a laptop and it had one drive C(OS) with 450 gb. i want the c - drive to be partitioned further 2 drives(D and E). will i able to do that ,if so please send me steps or screen shots...
    i followed the below steps:
    i partitoned using Shrink volume in Disk management and i aplit the drive as
    C-350 gb
    D-100 gb
    But i want to one more partition, so again i tried shrink volume in C drive but it dint allow me to shrink..
    Please suggest...
  2. Posts : 12,120
    Win 7 Pro x64 / Win 10 Pro
  3. Posts : 7,730
    Windows 7 Ultimate SP1 64-Bit
    Welcome to Windows Seven Forums.
    This tutorial shows you how to partition your hard drive during a Windows installation:
    Partition the Hard Drive in a Windows 7 Install
    This one shows you how to partition a hard drive using disk management or diskpart:
    Partition or Volume - Create New
    Partition Wizard is an excellent free alternative:
    http://www.partitionwizard.com/
  4. Posts : 4,751
    Please suggest...
    Try optimizing the C partition. If data is spread out on the partition, it will not let you shrink the volume.
    The best tool for this is free Partition Wizard bootable CD which has helped us do this hundreds of tmes here.
    Use the CD and not the Windows version as like with other Partition Managers the Windows installed version can fail, while the CD is not known to fail.
    If you have any further questions, please post back a screenshot of your maximized Disk Management drive map with listings, using the Snipping Tool in Start menu.
  6. Posts : 499
    Windows 7 Ultimate 64Bit
    I also recommend Partition Wizard. Works great.
  7. Posts : 2
    Thanks so much ......
  8. Posts : 7,730
    You're very welcome.
    Post back if you run into any difficulties.
