very strange problem with acpi battery control method
  1. Posts : 4
    windows 7 ultimate x64
    i have a sony vaio vpceb 190x with a windows 7 ultimate.after instaling VAIO control centar i get a message that the battery is not compatible ,press ok to hibernate....
    If i disable the acpi control method in device menager i dont get the error mesage but the computer does not have control over the battery.its like it dosent exist.
    Ive tryed with a diffrent windows instalation.but the problem is still there.
    Icant change anything in BIOS PM settings,
    Can anyone help me?
  2. Posts : 370
    Try uninstalling the Vaio Control Centre. That should let Windows handle the battery.
  3. Posts : 388
    Windows 7 Home Premium 64 Bit OS
    I agree- this is bloatware that you really don't need.
    You can control power options through Windows as Creepin has mentioned.
    If you want to tweak those settings you can click on the power icon in
    the system tray/ notification area of the taskbar-> more power options
    ->choose your power plan as required->Change plan settings->change advanced power settings
    In here you can change what your machine does for hibernate on battery and on power etc etc....
    If you don't want to fully remove the VAIO Control Center the following link will show
    you how to disable the battery care function - I think this what you are after.
    Link: http://digitalpbk.com/hardware/sony-...e-battery-life
    Hope this helps- cheers
  4. Posts : 4
    i've tried uninstaling Vaio control centar but the problem is still there.I have to format the parition and instal a fresh copy of windows.
    I need Vaio control centar for the shortcut keys on the laptop and HDMI conection.Without control centar the HDMI does not work properly.
  5. Posts : 4
    I ll try what AllOnTheBus sugested and get back to you
    Thank you for sugestion
  6. Posts : 388
    Yes ty
    Please post back results which may assist future visitors to this forum :)
  7. Posts : 4
    NO luck.the control cenatar was missing the battery option as shon on the picture.Here s a print screen
    Any other suggestions ?
    Attached Thumbnails Attached Thumbnails very strange problem with acpi battery control method-untitled.jpg
  8. Posts : 388
    Could be a problem with the software itself then.
    Take note of where the error is occuring and use the
    advice they are telling in regard to looking
    at the electronic manual for your product. See if there are any troubleshooting
    tips and/ or guides on the operation of that software.
    Otherwise- as Creepin said you may want to uninstall the software.
    As I previously mentioned you can do all sorts of settings for the battery
    using Windows itself, however you would be able to uninstall and reinstall
    a "fresh" version of your software if you so please.
    If that's what you decide to do, then look for the serial/ model numbers and any other
    indicators of your particular model and then Google around to find the .exe file
    to download and reinstall and the instructions for the safe uninstall and reinstall.
    The Sony support site for your country/ region would be
    a very good place to start and I would recommend getting the .exe file from there
    and NOT a third party.
    Good luck
    Note: Do not install the software from the following link as it is a Vista download, I
    have only provided this link AS AN EXAMPLE of the sort of informational page you will need to search for!!!!!
    http://esupport.sony.com/US/perl/swu...=4794&os_id=27
